RTEMS 4.10.0 On-Line Library
Configuration Parameters
PREV UP NEXT Bookshelf RTEMS Network Supplement
5.1.1: Configuration Parameters
The configuration structure for FTPD is as follows:
struct rtems_ftpd_configuration
   rtems_task_priority     priority;           /* FTPD task priority  */
   unsigned long           max_hook_filesize;  /* Maximum buffersize  */
                                               /*    for hooks        */
   int                     port;               /* Well-known port     */
   struct rtems_ftpd_hook  *hooks;             /* List of hooks       */
The FTPD task priority is specified with priority. Because hooks are not saved as files, the received data is placed in an allocated buffer. max_hook_filesize specifies the maximum size of this buffer. Finally, hooks is a pointer to the configured hooks structure.
