RTEMS 4.7.0 On-Line Library
Input and Output Primitives Manager read - Reads from a file.
RTEMS POSIX API User's Guide
5.4.5: read - Reads from a file.
CALLING SEQUENCE:
#include <unistd.h>
int read(
  int           fildes,
  void         *buf,
  unsigned int  nbyte
STATUS CODES:
On error, this routine returns -1 and sets errno to one of
the following:
- EAGAIN
The O_NONBLOCK flag is set for a file descriptor and the process
would be delayed in the I/O operation.
 - EBADF
Invalid file descriptor
 - EINTR
Function was interrupted by a signal.
 - EIO
Input or output error
DESCRIPTION:
The read() function reads nbyte bytes from the file
associated with fildes into the buffer pointed to by buf.
The read() function returns the number of bytes actually read
and placed in the buffer. This will be less than nbyte if:
- The number of bytes left in the file is less than
nbyte.
 - The
read() request was interrupted by a signal.
 - The file is a pipe or FIFO or special file with less than
nbytes
immediately available for reading.
When attempting to read from any empty pipe or FIFO:
- If no process has the pipe open for writing, zero is returned to
indicate end-of-file.
 - If some process has the pipe open for writing and O_NONBLOCK is set,
-1 is returned and
errno is set to EAGAIN.
 - If some process has the pipe open for writing and O_NONBLOCK is clear,
read() waits for some data to be written or the pipe to be closed.
When attempting to read from a file other than a pipe or FIFO and no data
is available.
- If O_NONBLOCK is set, -1 is returned and
 - If O_NONBLOCK is clear,
read() waits for some data to become
available.
 - The O_NONBLOCK flag is ignored if data is available.
NOTES:
NONE
