BSP and Device Driver Development Guide
The major number of a device driver is its index in the RTEMS Device Address Table.
A minor number is associated with each device instance
managed by a particular device driver.  An RTEMS minor number
is an unsigned32 entity.  Convention calls
dividing the bits in the minor number down into categories
like the following:
From the above, it should be clear that a single device driver can support multiple copies of the same board in a single system. The minor number is used to distinguish the devices.
