BSP and Device Driver Development Guide
This task should block until a packet arrives from the device.  If the
device is an Ethernet interface the function ether_input should be called
to forward the packet to the network stack.   The arguments to ether_input
are a pointer to the interface data structure, a pointer to the ethernet
header and a pointer to an mbuf containing the packet itself.
