BSP and Device Driver Development Guide
This corresponds to the driver read call.  After validating the minor
number and arguments, this call enables reads from the specified
memory area by invoking the user supplied "enable reads handler"
and then reads the indicated memory area.  When
invoked the argument_block is actually a pointer to the following
structure type:
typedef struct {
  rtems_unsigned32   offset;
  void              *buffer;
  rtems_unsigned32   length;
  rtems_unsigned32   status;
}   Non_volatile_memory_Driver_arguments;
The driver reads length bytes starting at offset into
the partition and places them at buffer.  The result is returned
in status.
After the read operation is complete, the user supplied "disable reads handler" is invoked to protect the memory area again.
