BSP and Device Driver Development Guide
The clock driver must supply a handler for the IO control device driver entry point. This functionality is used by other components -- notably the Shared Memory Driver to install a wrapper for the clock interrupt service routine. The following shows the functionality required:
rtems_device_driver Clock_control(
  rtems_device_major_number major,
  rtems_device_minor_number minor,
  void *pargp
  error check the argument pointer parameter
  if the command is "ISR"
    invoke the clock interrupt service routine
  else if the command is "NEW"
    install the requested handler
