RTEMS 4.7.0 On-Line Library
Console Driver Serial Driver Functioning Overview
BSP and Device Driver Development Guide
8.4: Serial Driver Functioning Overview
The following Figure shows how a Termios driven serial driver works:
Figure not included in this draft
The following list describes the basic flow.
- the application programmer uses standard C library call (printf,
scanf, read, write, etc.),
 - C library (in fact that's Cygnus Newlib) calls RTEMS
system call interface. This code can be found in the
c/src/lib/libc directory.
 - Glue code calls the serial driver entry routines.
