BSP and Device Driver Development Guide
When building a BSP or an application using that BSP, it is necessary
to tailor the compilation arguments to account for compiler flags, use
custom linker scripts, include the RTEMS libraries, etc..  The BSP
must be built using this information.  Later, once the BSP is installed
with the toolset, this same information must be used when building the
application.  So a BSP must include a build configuration file.  The
configuration file is make/custom/BSP.cfg.
The configuration file is taken into account when building one's
application using the RTEMS template Makefiles (make/templates).
It is strongly advised to use these template Makefiles since they
encapsulate a number of build rules along with the compile and link
time options necessary to execute on the target board.
There is a template Makefile provided for each of class of RTEMS Makefiles. The purpose of each class of RTEMS Makefile is to:
The following is a shortened and heavily commented version of the
make customization file for the gen68340 BSP.  The original source
for this file can be found in the make/custom directory.
# The RTEMS CPU Family and Model RTEMS_CPU=m68k RTEMS_CPU_MODEL=mcpu32 include $(RTEMS_ROOT)/make/custom/default.cfg # The name of the BSP directory used for the actual source code. # This allows for build variants of the same BSP source. RTEMS_BSP_FAMILY=gen68340 # CPU flag to pass to GCC CPU_CFLAGS = -mcpu32 # optimization flag to pass to GCC CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer # The name of the start file to be linked with. This file is the first # part of the BSP which executes. START_BASE=start340 # This make-exe macro is used in template makefiles to build the # final executable. Any other commands to follow, just as using # objcopy to build a PROM image or converting the executable to binary. define make-exe $(CC) $(CFLAGS) $(CFLAGS_LD) -o $(basename $@).exe $(LINK_OBJS) $(NM) -g -n $(basename $@).exe > $(basename $@).num $(SIZE) $(basename $@).exe endif
