#define | CPU_INLINE_ENABLE_DISPATCH TRUE |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE |
#define | CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE |
#define | CPU_ALLOCATE_INTERRUPT_STACK TRUE |
#define | CPU_ISR_PASSES_FRAME_POINTER 0 |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_STRUCTURE_ALIGNMENT |
#define | CPU_TIMESTAMP_USE_INT64_INLINE TRUE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY TRUE |
#define | CPU_BIG_ENDIAN FALSE |
#define | CPU_LITTLE_ENDIAN TRUE |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0 |
#define | I386_CONTEXT_CONTROL_ESP_OFFSET 4 |
#define | I386_CONTEXT_CONTROL_EBP_OFFSET 8 |
#define | I386_CONTEXT_CONTROL_EBX_OFFSET 12 |
#define | I386_CONTEXT_CONTROL_ESI_OFFSET 16 |
#define | I386_CONTEXT_CONTROL_EDI_OFFSET 20 |
#define | _CPU_Context_Get_SP(_context) (_context)->esp |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MODES_INTERRUPT_LEVEL 0x00000001 /* interrupt level in mode */ |
#define | CPU_MODES_INTERRUPT_MASK 0x00000001 /* interrupt level in mode */ |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE 4096 |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 4 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 16 |
#define | _CPU_ISR_Disable(_level) i386_disable_interrupts( _level ) |
#define | _CPU_ISR_Enable(_level) i386_enable_interrupts( _level ) |
#define | _CPU_ISR_Flash(_level) i386_flash_interrupts( _level ) |
| #define | _CPU_ISR_Set_level(_new_level) |
| #define | _CPU_Interrupt_stack_setup(_lo, _hi) |
#define | CPU_EFLAGS_INTERRUPTS_ON 0x00003202 |
#define | CPU_EFLAGS_INTERRUPTS_OFF 0x00003002 |
| #define | _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area) |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
| #define | _CPU_Context_Initialize_fp(_fp_area) |
| #define | _CPU_Fatal_halt(_source, _error) |
#define | CPU_USE_GENERIC_BITFIELD_CODE FALSE |
#define | CPU_USE_GENERIC_BITFIELD_DATA FALSE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
| enum | Intel_symbolic_exception_name {
I386_EXCEPTION_DIVIDE_BY_ZERO = 0,
I386_EXCEPTION_DEBUG = 1,
I386_EXCEPTION_NMI = 2,
I386_EXCEPTION_BREAKPOINT = 3,
I386_EXCEPTION_OVERFLOW = 4,
I386_EXCEPTION_BOUND = 5,
I386_EXCEPTION_ILLEGAL_INSTR = 6,
I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
I386_EXCEPTION_DOUBLE_FAULT = 8,
I386_EXCEPTION_I386_COPROC_SEG_ERR = 9,
I386_EXCEPTION_INVALID_TSS = 10,
I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
I386_EXCEPTION_STACK_SEGMENT_FAULT = 12,
I386_EXCEPTION_GENERAL_PROT_ERR = 13,
I386_EXCEPTION_PAGE_FAULT = 14,
I386_EXCEPTION_INTEL_RES15 = 15,
I386_EXCEPTION_FLOAT_ERROR = 16,
I386_EXCEPTION_ALIGN_CHECK = 17,
I386_EXCEPTION_MACHINE_CHECK = 18,
I386_EXCEPTION_ENTER_RDBG = 50
Intel I386 CPU Dependent Source.
This include file contains information pertaining to the Intel i386 processor.
