#define | __fts_stat_t struct stat |
#define | __fts_nlink_t nlink_t |
#define | __fts_ino_t ino_t |
#define | FTS_COMFOLLOW 0x001 /* follow command line symlinks */ |
#define | FTS_LOGICAL 0x002 /* logical walk */ |
#define | FTS_NOCHDIR 0x004 /* don't change directories */ |
#define | FTS_NOSTAT 0x008 /* don't get stat info */ |
#define | FTS_PHYSICAL 0x010 /* physical walk */ |
#define | FTS_SEEDOT 0x020 /* return dot and dot-dot */ |
#define | FTS_XDEV 0x040 /* don't cross devices */ |
#define | FTS_WHITEOUT 0x080 /* return whiteout information */ |
#define | FTS_OPTIONMASK 0x0ff /* valid user option mask */ |
#define | FTS_NAMEONLY 0x100 /* (private) child names only */ |
#define | FTS_STOP 0x200 /* (private) unrecoverable error */ |
#define | FTS_ROOTPARENTLEVEL -1 |
#define | FTS_ROOTLEVEL 0 |
#define | FTS_D 1 /* preorder directory */ |
#define | FTS_DC 2 /* directory that causes cycles */ |
#define | FTS_DEFAULT 3 /* none of the above */ |
#define | FTS_DNR 4 /* unreadable directory */ |
#define | FTS_DOT 5 /* dot or dot-dot */ |
#define | FTS_DP 6 /* postorder directory */ |
#define | FTS_ERR 7 /* error; errno is set */ |
#define | FTS_F 8 /* regular file */ |
#define | FTS_INIT 9 /* initialized only */ |
#define | FTS_NS 10 /* stat(2) failed */ |
#define | FTS_NSOK 11 /* no stat(2) requested */ |
#define | FTS_SL 12 /* symbolic link */ |
#define | FTS_SLNONE 13 /* symbolic link without target */ |
#define | FTS_W 14 /* whiteout object */ |
#define | FTS_DONTCHDIR 0x01 /* don't chdir .. to the parent */ |
#define | FTS_SYMFOLLOW 0x02 /* followed a symlink to get here */ |
#define | FTS_ISW 0x04 /* this is a whiteout object */ |
#define | FTS_AGAIN 1 /* read node again */ |
#define | FTS_FOLLOW 2 /* follow symbolic link */ |
#define | FTS_NOINSTR 3 /* no instructions */ |
#define | FTS_SKIP 4 /* discard node */ |
#define | __RENAME(n) |
#define | fts_children rtems_shell_fts_children |
#define | fts_close rtems_shell_fts_close |
#define | fts_open rtems_shell_fts_open |
#define | fts_read rtems_shell_fts_read |
#define | fts_set rtems_shell_fts_set |
