#include <setjmp.h>
#include <sys/cdefs.h>
#define | PATH_T RTEMS_SHELL_CP_PATH_T |
#define | to cp_globals->to |
#define | info cp_globals->info |
#define | myuid cp_globals->myuid |
#define | fflag cp_globals->fflag |
#define | iflag cp_globals->iflag |
#define | lflag cp_globals->lflag |
#define | nflag cp_globals->nflag |
#define | pflag cp_globals->pflag |
#define | vflag cp_globals->vflag |
#define | myumask cp_globals->myumask |
#define | exit_jump &(cp_globals->exit_jmp) |
#define | copy_fifo rtems_shell_cp_copy_fifo |
#define | copy_file rtems_shell_cp_copy_file |
#define | copy_link rtems_shell_cp_copy_link |
#define | copy_special rtems_shell_cp_copy_special |
#define | set_utimes rtems_shell_cp_set_utimes |
#define | setfile rtems_shell_cp_setfile |
#define | usage rtems_shell_cp_usage |
__BEGIN_DECLS int | copy_fifo (rtems_shell_cp_globals *cp_globals, struct stat *, int) |
int | copy_file (rtems_shell_cp_globals *cp_globals, FTSENT *, int) |
int | copy_link (rtems_shell_cp_globals *cp_globals, FTSENT *, int) |
int | copy_special (rtems_shell_cp_globals *cp_globals, struct stat *, int) |
int | set_utimes (const char *, struct stat *) |
int | setfile (rtems_shell_cp_globals *cp_globals, struct stat *, int) |
int | preserve_dir_acls (struct stat *, char *, char *) |
int | preserve_fd_acls (int, int) |
void | usage (rtems_shell_cp_globals *cp_globals) |
