| #define | RTEMS_BLKDEV_START_BLOCK(req) (req->bufs[0].block) |
| | The start block in a request. More...
| #define | RTEMS_GENERIC_BLOCK_DEVICE_DRIVER_ENTRIES |
| | The device driver interface conventions suppose that a driver may contain an initialize, open, close, read, write and IO control entry points. More...
#define | RTEMS_BLKIO_REQUEST _IOWR('B', 1, rtems_blkdev_request) |
#define | RTEMS_BLKIO_GETMEDIABLKSIZE _IOR('B', 2, uint32_t) |
#define | RTEMS_BLKIO_GETBLKSIZE _IOR('B', 3, uint32_t) |
#define | RTEMS_BLKIO_SETBLKSIZE _IOW('B', 4, uint32_t) |
#define | RTEMS_BLKIO_GETSIZE _IOR('B', 5, rtems_blkdev_bnum) |
#define | RTEMS_BLKIO_SYNCDEV _IO('B', 6) |
#define | RTEMS_BLKIO_DELETED _IO('B', 7) |
#define | RTEMS_BLKIO_CAPABILITIES _IO('B', 8) |
#define | RTEMS_BLKIO_GETDISKDEV _IOR('B', 9, rtems_disk_device *) |
#define | RTEMS_BLKIO_PURGEDEV _IO('B', 10) |
#define | RTEMS_BLKIO_GETDEVSTATS _IOR('B', 11, rtems_blkdev_stats *) |
#define | RTEMS_BLKIO_RESETDEVSTATS _IO('B', 12) |
| #define | RTEMS_BLKDEV_CAP_MULTISECTOR_CONT (1 << 0) |
| | Only consecutive multi-sector buffer requests are supported. More...
| #define | RTEMS_BLKDEV_CAP_SYNC (1 << 1) |
| | The driver will accept a sync call. More...
| int | rtems_blkdev_ioctl (rtems_disk_device *dd, uint32_t req, void *argp) |
| | Common IO control primitive. More...
| rtems_status_code | rtems_blkdev_create (const char *device, uint32_t media_block_size, rtems_blkdev_bnum media_block_count, rtems_block_device_ioctl handler, void *driver_data) |
| | Creates a block device. More...
| rtems_status_code | rtems_blkdev_create_partition (const char *partition, const char *parent_block_device, rtems_blkdev_bnum media_block_begin, rtems_blkdev_bnum media_block_count) |
| | Creates a partition within a parent block device. More...
void | rtems_blkdev_print_stats (const rtems_blkdev_stats *stats, rtems_printk_plugin_t print, void *print_arg) |
| | Prints the block device statistics.
void | rtems_blkstats (FILE *output, const char *device, bool reset) |
| | Block device statistics command.
| rtems_device_driver | rtems_blkdev_generic_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| | Generic block device read primitive. More...
| rtems_device_driver | rtems_blkdev_generic_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| | Generic block device write primitive. More...
| rtems_device_driver | rtems_blkdev_generic_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| | Generic block device open primitive. More...
| rtems_device_driver | rtems_blkdev_generic_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| | Generic block device close primitive. More...
| rtems_device_driver | rtems_blkdev_generic_ioctl (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| | Generic block device IO control primitive. More...
