RTEMS 5.2
vmeTsi148DMA Support More...
#include <bsp/vmeTsi148.h>Go to the source code of this file.
Typedefs | |
| typedef struct VmeTsi148DmaListDescriptorRec_ * | VmeTsi148DmaListDescriptor |
| int | vmeTsi148DmaSetupXX (BERegister *base, int channel, uint32_t mode, uint32_t xfer_mode, void *custom) |
| int | vmeTsi148DmaSetup (int channel, uint32_t mode, uint32_t xfer_mode, void *custom) |
| int | vmeTsi148DmaListStartXX (BERegister *base, int channel, VmeTsi148DmaListDescriptor d) |
| int | vmeTsi148DmaListStart (int channel, VmeTsi148DmaListDescriptor d) |
| int | vmeTsi148DmaStartXX (BERegister *base, int channel, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
| int | vmeTsi148DmaStart (int channel, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
| uint32_t | vmeTsi148DmaStatusXX (BERegister *base, int channel) |
| uint32_t | vmeTsi148DmaStatus (int channel) |
| struct VMEDmaListClassRec_ | vmeTsi148DmaListClass |
