RTEMS 5.2
v850.h
1
12/*
13 * COPYRIGHT (c) 1989-2012.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_V850_H
22#define _RTEMS_SCORE_V850_H
23
24#ifdef __cplusplus
25extern "C" {
26#endif
27
28/*
29 * This file contains the information required to build
30 * RTEMS for a particular member of the NO CPU family.
31 * It does this by setting variables to indicate which
32 * implementation dependent features are present in a particular
33 * member of the family.
34 *
35 * This is a good place to list all the known CPU models
36 * that this port supports and which RTEMS CPU model they correspond
37 * to.
38 */
39
40#if defined(rtems_multilib)
41/*
42 * Figure out all CPU Model Feature Flags based upon compiler
43 * predefines.
44 */
45#define CPU_MODEL_NAME "rtems_multilib"
46#define V850_HAS_FPU 0
47#define V850_HAS_BYTE_SWAP_INSTRUCTION 0
48
49#elif defined(__v850e2v3__)
50#define CPU_MODEL_NAME "v850e2v3"
51#define V850_HAS_FPU 1
52#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
53
54#elif defined(__v850e2__)
55#define CPU_MODEL_NAME "v850e2"
56#define V850_HAS_FPU 0
57#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
58
59#elif defined(__v850es__)
60#define CPU_MODEL_NAME "v850es"
61#define V850_HAS_FPU 0
62#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
63
64#elif defined(__v850e1__)
65#define CPU_MODEL_NAME "v850e1"
66#define V850_HAS_FPU 0
67#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
68
69#elif defined(__v850e__)
70#define CPU_MODEL_NAME "v850e"
71#define V850_HAS_FPU 0
72#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
73
74#else
75#define CPU_MODEL_NAME "v850"
76#define V850_HAS_FPU 0
77#define V850_HAS_BYTE_SWAP_INSTRUCTION 0
78
79#endif
80
81/*
82 * Define the name of the CPU family.
83 */
84#define CPU_NAME "v850 CPU"
85
86/*
87 * Method to set the Program Status Word (PSW)
88 */
89#define v850_set_psw( _psw ) \
90 __asm__ __volatile__( "ldsr %0, psw" : : "r" (_psw) )
91
92/*
93 * Method to obtain the Program Status Word (PSW)
94 */
95#define v850_get_psw( _psw ) \
96 __asm__ __volatile__( "stsr psw, %0" : "=&r" (_psw) )
97
98/*
99 * Masks and bits in the Program Status Word (PSW)
100 */
101#define V850_PSW_ZERO_MASK 0x01
102#define V850_PSW_IS_ZERO 0x01
103#define V850_PSW_IS_NOT 0x00
104
105#define V850_PSW_SIGN_MASK 0x02
106#define V850_PSW_SIGN_IS_NEGATIVE 0x02
107#define V850_PSW_SIGN_IS_ZERO_OR_POSITIVE 0x00
108
109#define V850_PSW_OVERFLOW_MASK 0x02
110#define V850_PSW_OVERFLOW_OCCURRED 0x02
111#define V850_PSW_OVERFLOW_DID_NOT_OCCUR 0x00
112
113#define V850_PSW_CARRY_OR_BORROW_MASK 0x04
114#define V850_PSW_CARRY_OR_BORROW_OCCURRED 0x04
115#define V850_PSW_CARRY_OR_BORROW_DID_NOT_OCCUR 0x00
116
117#define V850_PSW_SATURATION_MASK 0x10
118#define V850_PSW_SATURATION_OCCURRED 0x10
119#define V850_PSW_SATURATION_DID_NOT_OCCUR 0x00
120
121#define V850_PSW_INTERRUPT_DISABLE_MASK 0x20
122#define V850_PSW_INTERRUPT_DISABLE 0x20
123#define V850_PSW_INTERRUPT_ENABLE 0x00
124
125#define V850_PSW_EXCEPTION_IN_PROCESS_MASK 0x40
126#define V850_PSW_EXCEPTION_IN_PROCESS 0x40
127#define V850_PSW_EXCEPTION_NOT_IN_PROCESS 0x00
128
129#define V850_PSW_NMI_IN_PROCESS_MASK 0x80
130#define V850_PSW_NMI_IN_PROCESS 0x80
131#define V850_PSW_NMI_NOT_IN_PROCESS 0x00
132
133#ifdef __cplusplus
134}
135#endif
136
137#endif /* _RTEMS_SCORE_V850_H */
