RTEMS 5.2
Data Fields | |
| struct drvmgr_dev * | dev |
| struct grpci_regs * | regs |
| int | irq |
| int | minor |
| uint32_t | bar1_pci_adr |
| uint32_t | bar1_size |
| int | bt_enabled |
| unsigned int | pci_area |
| unsigned int | pci_area_end |
| unsigned int | pci_io |
| unsigned int | pci_conf |
| unsigned int | pci_conf_end |
| uint32_t | devVend |
| struct drvmgr_map_entry | maps_up [2] |
| struct drvmgr_map_entry | maps_down [2] |
| struct pcibus_config | config |
