struct drvmgr_dev * | dev |
struct grpci2_regs * | regs |
unsigned char | ver |
char | irq |
char | irq_mode |
char | irq_dma |
char | bt_enabled |
unsigned int | irq_mask |
unsigned int | latency_timer |
struct grpci2_pcibar_cfg * | barcfg |
unsigned int | pci_area |
unsigned int | pci_area_end |
unsigned int | pci_io |
unsigned int | pci_conf |
unsigned int | pci_conf_end |
uint32_t | devVend |
struct drvmgr_map_entry | maps_up [7] |
struct drvmgr_map_entry | maps_down [2] |
struct pcibus_config | config |
void(* | dma_isr )(void *data) |
void * | dma_isr_arg |
- bsps/shared/grlib/pci/grpci2.c
