RTEMS 5.2
Data Fields | |
| volatile ALT_GPIO_SWPORTA_DR_t | gpio_swporta_dr |
| volatile ALT_GPIO_SWPORTA_DDR_t | gpio_swporta_ddr |
| volatile uint32_t | _pad_0x8_0x2f [10] |
| volatile ALT_GPIO_INTEN_t | gpio_inten |
| volatile ALT_GPIO_INTMSK_t | gpio_intmask |
| volatile ALT_GPIO_INTTYPE_LEVEL_t | gpio_inttype_level |
| volatile ALT_GPIO_INT_POL_t | gpio_int_polarity |
| volatile ALT_GPIO_INTSTAT_t | gpio_intstatus |
| volatile ALT_GPIO_RAW_INTSTAT_t | gpio_raw_intstatus |
| volatile ALT_GPIO_DEBOUNCE_t | gpio_debounce |
| volatile ALT_GPIO_PORTA_EOI_t | gpio_porta_eoi |
| volatile ALT_GPIO_EXT_PORTA_t | gpio_ext_porta |
| volatile uint32_t | _pad_0x54_0x5f [3] |
| volatile ALT_GPIO_LS_SYNC_t | gpio_ls_sync |
| volatile ALT_GPIO_ID_CODE_t | gpio_id_code |
| volatile uint32_t | _pad_0x68_0x6b |
| volatile ALT_GPIO_VER_ID_CODE_t | gpio_ver_id_code |
| volatile ALT_GPIO_CFG_REG2_t | gpio_config_reg2 |
| volatile ALT_GPIO_CFG_REG1_t | gpio_config_reg1 |
| volatile uint32_t | _pad_0x78_0x80 [2] |
