RTEMS 5.2
Stack Checker Information. More...
| #define | RTEMS_STACK_CHECKER_EXTENSION |
| Stack Checker Extension Set Definition. More... | |
| bool | rtems_stack_checker_is_blown (void) |
| Checks if current task is blown its stack. More... | |
| void | rtems_stack_checker_report_usage (void) |
| Print the stack usage report using printk. More... | |
| void | rtems_stack_checker_report_usage_with_plugin (const rtems_printer *printer) |
| Print the stack usage report using caller's routine. More... | |
| bool | rtems_stack_checker_create_extension (Thread_Control *running, Thread_Control *the_thread) |
| Stack Checker Task Create Extension. More... | |
| void | rtems_stack_checker_begin_extension (Thread_Control *executing) |
| void | rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir) |
| Stack Checker Task Context Switch Extension. More... | |
This include file contains information necessary to utilize and install the stack checker mechanism.
