RTEMS 5.2
cpu.h
1
10/*
11 * COPYRIGHT (c) 1989-2011.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_SCORE_CPU_H
20#define _RTEMS_SCORE_CPU_H
21
22#ifdef __cplusplus
23extern "C" {
24#endif
25
27#include <rtems/score/sparc.h>
28
29/* conditional compilation parameters */
30
31/*
32 * The SPARC ABI is a bit special with respect to the floating point context.
33 * The complete floating point context is volatile. Thus, from an ABI point
34 * of view nothing needs to be saved and restored during a context switch.
35 * Instead the floating point context must be saved and restored during
36 * interrupt processing. Historically, the deferred floating point switch was
37 * used for SPARC and the complete floating point context is saved and
38 * restored during a context switch to the new floating point unit owner.
39 * This is a bit dangerous since post-switch actions (e.g. signal handlers)
40 * and context switch extensions may silently corrupt the floating point
41 * context.
42 *
43 * The floating point unit is disabled for interrupt handlers. Thus, in case
44 * an interrupt handler uses the floating point unit then this will result in a
45 * trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
46 *
47 * In uniprocessor configurations, a lazy floating point context switch is
48 * used. In case an active floating point thread is interrupted (PSR[EF] == 1)
49 * and a thread dispatch is carried out, then this thread is registered as the
50 * floating point owner. When a floating point owner is present during a
51 * context switch, the floating point unit is disabled for the heir thread
52 * (PSR[EF] == 0). The floating point disabled trap checks that the use of the
53 * floating point unit is allowed and saves/restores the floating point context
54 * on demand.
55 *
56 * In SMP configurations, the deferred floating point switch is not supported
57 * in principle. So, use here a synchronous floating point switching.
58 * Synchronous means that the volatile floating point context is saved and
59 * restored around a thread dispatch issued during interrupt processing. Thus
60 * post-switch actions and context switch extensions may safely use the
61 * floating point unit.
62 */
63#if SPARC_HAS_FPU == 1
64 #if defined(RTEMS_SMP)
65 #define SPARC_USE_SYNCHRONOUS_FP_SWITCH
66 #else
67 #define SPARC_USE_LAZY_FP_SWITCH
68 #endif
69#endif
70
81#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
82
91#define CPU_ISR_PASSES_FRAME_POINTER FALSE
92
101#if ( SPARC_HAS_FPU == 1 ) && !defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
102 #define CPU_HARDWARE_FP TRUE
103#else
104 #define CPU_HARDWARE_FP FALSE
105#endif
106
111#define CPU_SOFTWARE_FP FALSE
112
121#define CPU_ALL_TASKS_ARE_FP FALSE
122
132#define CPU_IDLE_TASK_IS_FP FALSE
133
134#define CPU_USE_DEFERRED_FP_SWITCH FALSE
135
136#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
137
147#define CPU_STACK_GROWS_UP FALSE
148
149/* LEON3 systems may use a cache line size of 64 */
150#define CPU_CACHE_LINE_BYTES 64
151
152#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
153
161#define CPU_MODES_INTERRUPT_MASK 0x0000000F
162
163#ifndef ASM
170typedef struct {
172 uint32_t l0;
174 uint32_t l1;
176 uint32_t l2;
178 uint32_t l3;
180 uint32_t l4;
182 uint32_t l5;
184 uint32_t l6;
186 uint32_t l7;
188 uint32_t i0;
190 uint32_t i1;
192 uint32_t i2;
194 uint32_t i3;
196 uint32_t i4;
198 uint32_t i5;
200 uint32_t i6_fp;
202 uint32_t i7;
205
206 /*
207 * The following are for the callee to save the register arguments in
208 * should this be necessary.
209 */
211 uint32_t saved_arg0;
213 uint32_t saved_arg1;
215 uint32_t saved_arg2;
217 uint32_t saved_arg3;
219 uint32_t saved_arg4;
221 uint32_t saved_arg5;
223 uint32_t pad0;
225
226#endif /* ASM */
227
229#define CPU_STACK_FRAME_L0_OFFSET 0x00
231#define CPU_STACK_FRAME_L1_OFFSET 0x04
233#define CPU_STACK_FRAME_L2_OFFSET 0x08
235#define CPU_STACK_FRAME_L3_OFFSET 0x0c
237#define CPU_STACK_FRAME_L4_OFFSET 0x10
239#define CPU_STACK_FRAME_L5_OFFSET 0x14
241#define CPU_STACK_FRAME_L6_OFFSET 0x18
243#define CPU_STACK_FRAME_L7_OFFSET 0x1c
245#define CPU_STACK_FRAME_I0_OFFSET 0x20
247#define CPU_STACK_FRAME_I1_OFFSET 0x24
249#define CPU_STACK_FRAME_I2_OFFSET 0x28
251#define CPU_STACK_FRAME_I3_OFFSET 0x2c
253#define CPU_STACK_FRAME_I4_OFFSET 0x30
255#define CPU_STACK_FRAME_I5_OFFSET 0x34
257#define CPU_STACK_FRAME_I6_FP_OFFSET 0x38
259#define CPU_STACK_FRAME_I7_OFFSET 0x3c
261#define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET 0x40
263#define CPU_STACK_FRAME_SAVED_ARG0_OFFSET 0x44
265#define CPU_STACK_FRAME_SAVED_ARG1_OFFSET 0x48
267#define CPU_STACK_FRAME_SAVED_ARG2_OFFSET 0x4c
269#define CPU_STACK_FRAME_SAVED_ARG3_OFFSET 0x50
271#define CPU_STACK_FRAME_SAVED_ARG4_OFFSET 0x54
273#define CPU_STACK_FRAME_SAVED_ARG5_OFFSET 0x58
275#define CPU_STACK_FRAME_PAD0_OFFSET 0x5c
276
277#define CPU_MAXIMUM_PROCESSORS 32
278
300#ifndef ASM
302
318typedef struct {
320 uint32_t g5;
322 uint32_t g7;
323
331 double l0_and_l1;
333 uint32_t l2;
335 uint32_t l3;
337 uint32_t l4;
339 uint32_t l5;
341 uint32_t l6;
343 uint32_t l7;
344
346 uint32_t i0;
348 uint32_t i1;
350 uint32_t i2;
352 uint32_t i3;
354 uint32_t i4;
356 uint32_t i5;
358 uint32_t i6_fp;
360 uint32_t i7;
361
363 uint32_t o6_sp;
368 uint32_t o7;
369
371 uint32_t psr;
377 uint32_t isr_dispatch_disable;
378
379#if defined(SPARC_USE_LAZY_FP_SWITCH)
380 Context_Control_fp *fp_context;
381#endif
382
383#if defined(RTEMS_SMP)
384 volatile uint32_t is_executing;
385#endif
387
393#define _CPU_Context_Get_SP( _context ) \
394 (_context)->o6_sp
395
396#ifdef RTEMS_SMP
397 static inline bool _CPU_Context_Get_is_executing(
399 )
400 {
401 return context->is_executing;
402 }
403
404 static inline void _CPU_Context_Set_is_executing(
406 bool is_executing
407 )
408 {
409 context->is_executing = is_executing;
410 }
411#endif
412
413#endif /* ASM */
414
415/*
416 * Offsets of fields with Context_Control for assembly routines.
417 */
418
420#define G5_OFFSET 0x00
422#define G7_OFFSET 0x04
423
425#define L0_OFFSET 0x08
427#define L1_OFFSET 0x0C
429#define L2_OFFSET 0x10
431#define L3_OFFSET 0x14
433#define L4_OFFSET 0x18
435#define L5_OFFSET 0x1C
437#define L6_OFFSET 0x20
439#define L7_OFFSET 0x24
440
442#define I0_OFFSET 0x28
444#define I1_OFFSET 0x2C
446#define I2_OFFSET 0x30
448#define I3_OFFSET 0x34
450#define I4_OFFSET 0x38
452#define I5_OFFSET 0x3C
454#define I6_FP_OFFSET 0x40
456#define I7_OFFSET 0x44
457
459#define O6_SP_OFFSET 0x48
461#define O7_OFFSET 0x4C
462
464#define PSR_OFFSET 0x50
466#define ISR_DISPATCH_DISABLE_STACK_OFFSET 0x54
467
468#if defined(RTEMS_SMP)
469 #define SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x58
470#endif
471
472#ifndef ASM
478struct Context_Control_fp {
480 double f0_f1;
482 double f2_f3;
484 double f4_f5;
486 double f6_f7;
488 double f8_f9;
490 double f10_f11;
492 double f12_f13;
494 double f14_f15;
496 double f16_f17;
498 double f18_f19;
500 double f20_f21;
502 double f22_f23;
504 double f24_f25;
506 double f26_f27;
508 double f28_f29;
510 double f30_f31;
512 uint32_t fsr;
513};
514
515#endif /* ASM */
516
517/*
518 * Offsets of fields with Context_Control_fp for assembly routines.
519 */
520
522#define FO_F1_OFFSET 0x00
524#define F2_F3_OFFSET 0x08
526#define F4_F5_OFFSET 0x10
528#define F6_F7_OFFSET 0x18
530#define F8_F9_OFFSET 0x20
532#define F1O_F11_OFFSET 0x28
534#define F12_F13_OFFSET 0x30
536#define F14_F15_OFFSET 0x38
538#define F16_F17_OFFSET 0x40
540#define F18_F19_OFFSET 0x48
542#define F2O_F21_OFFSET 0x50
544#define F22_F23_OFFSET 0x58
546#define F24_F25_OFFSET 0x60
548#define F26_F27_OFFSET 0x68
550#define F28_F29_OFFSET 0x70
552#define F3O_F31_OFFSET 0x78
554#define FSR_OFFSET 0x80
555
557#define CONTEXT_CONTROL_FP_SIZE 0x84
558
559#ifndef ASM
560
571typedef struct {
575 uint32_t psr;
577 uint32_t pc;
579 uint32_t npc;
581 uint32_t g1;
583 uint32_t g2;
585 uint32_t g3;
587 uint32_t g4;
589 uint32_t g5;
593 uint32_t g7;
595 uint32_t i0;
597 uint32_t i1;
599 uint32_t i2;
601 uint32_t i3;
603 uint32_t i4;
605 uint32_t i5;
607 uint32_t i6_fp;
609 uint32_t i7;
611 uint32_t y;
613 uint32_t tpc;
615
616#endif /* ASM */
617
618#ifndef ASM
627typedef struct {
629 uint32_t mov_psr_l0;
637
648
652#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
653
654#endif
655
661#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
662
686#define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
687
692#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 511
693
698#define SPARC_SYNCHRONOUS_TRAP_BIT_MASK 0x100
699
703#define SPARC_ASYNCHRONOUS_TRAP( _trap ) (_trap)
704
708#define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 256 )
709
713#define SPARC_REAL_TRAP_NUMBER( _trap ) ((_trap) % 256)
714
719#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
720
729#define CPU_STACK_MINIMUM_SIZE (1024*4)
730
734#define CPU_SIZEOF_POINTER 4
735
742#define CPU_ALIGNMENT 8
743
755#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
756
761#define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
762
763#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
764
765#ifndef ASM
766
767/*
768 * ISR handler macros
769 */
770
774#define _CPU_Initialize_vectors()
775
780#define _CPU_ISR_Disable( _level ) \
781 (_level) = sparc_disable_interrupts()
782
788#define _CPU_ISR_Enable( _level ) \
789 sparc_enable_interrupts( _level )
790
797#define _CPU_ISR_Flash( _level ) \
798 sparc_flash_interrupts( _level )
799
800#define _CPU_ISR_Is_enabled( _isr_cookie ) \
801 sparc_interrupt_is_enabled( _isr_cookie )
802
804{
805 return ( level & SPARC_PSR_PIL_MASK ) == 0;
806}
807
813#define _CPU_ISR_Set_level( _newlevel ) \
814 sparc_enable_interrupts( _newlevel << 8)
815
823uint32_t _CPU_ISR_Get_level( void );
824
825/* end of ISR handler macros */
826
827/* Context handler macros */
828
851 Context_Control *the_context,
852 uint32_t *stack_base,
853 uint32_t size,
854 uint32_t new_level,
855 void *entry_point,
856 bool is_fp,
857 void *tls_area
858);
859
873#define _CPU_Context_Initialization_at_thread_begin() \
874 do { \
875 __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
876 } while (0)
877
886#define _CPU_Context_Restart_self( _the_context ) \
887 _CPU_Context_restore( (_the_context) );
888
892#define _CPU_Context_Initialize_fp( _destination ) \
893 do { } while ( 0 )
894
898#define _CPU_Context_save_fp( _fp_context_ptr ) \
899 do { } while ( 0 )
900
904#define _CPU_Context_restore_fp( _fp_context_ptr ) \
905 do { } while ( 0 )
906/* end of Context handler macros */
907
908/* Fatal Error manager macros */
909
915extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
917
918/* end of Fatal Error manager macros */
919
920/* Bitfield handler macros */
921
922#if ( SPARC_HAS_BITSCAN == 0 )
927 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
928#else
929 #error "scan instruction not currently supported by RTEMS!!"
930#endif
931
932/* end of Bitfield handler macros */
933
934/* functions */
935
941void _CPU_Initialize(void);
942
943typedef void ( *CPU_ISR_raw_handler )( void );
944
956 uint32_t vector,
957 CPU_ISR_raw_handler new_handler,
958 CPU_ISR_raw_handler *old_handler
959);
960
961typedef void ( *CPU_ISR_handler )( uint32_t );
962
974 uint32_t vector,
975 CPU_ISR_handler new_handler,
976 CPU_ISR_handler *old_handler
977);
978
979void *_CPU_Thread_Idle_body( uintptr_t ignored );
980
990 Context_Control *run,
991 Context_Control *heir
992);
993
1003 Context_Control *new_context
1005
1006#if defined(RTEMS_SMP)
1007 uint32_t _CPU_SMP_Initialize( void );
1008
1009 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
1010
1011 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
1012
1013 void _CPU_SMP_Prepare_start_multitasking( void );
1014
1015 #if defined(__leon__) && !defined(RTEMS_PARAVIRT)
1016 static inline uint32_t _CPU_SMP_Get_current_processor( void )
1017 {
1018 return _LEON3_Get_current_processor();
1019 }
1020 #else
1021 uint32_t _CPU_SMP_Get_current_processor( void );
1022 #endif
1023
1024 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
1025
1026 static inline void _CPU_SMP_Processor_event_broadcast( void )
1027 {
1028 __asm__ volatile ( "" : : : "memory" );
1029 }
1030
1031 static inline void _CPU_SMP_Processor_event_receive( void )
1032 {
1033 __asm__ volatile ( "" : : : "memory" );
1034 }
1035#endif
1036
1037#if defined(SPARC_USE_LAZY_FP_SWITCH)
1038#define _CPU_Context_Destroy( _the_thread, _the_context ) \
1039 do { \
1040 Per_CPU_Control *cpu_self = _Per_CPU_Get(); \
1041 Thread_Control *_fp_owner = cpu_self->cpu_per_cpu.fp_owner; \
1042 if ( _fp_owner == _the_thread ) { \
1043 cpu_self->cpu_per_cpu.fp_owner = NULL; \
1044 } \
1045 } while ( 0 )
1046#endif
1047
1048typedef struct {
1049 uint32_t trap;
1052
1054
1075static inline uint32_t CPU_swap_u32(
1076 uint32_t value
1077)
1078{
1079 uint32_t byte1, byte2, byte3, byte4, swapped;
1080
1081 byte4 = (value >> 24) & 0xff;
1082 byte3 = (value >> 16) & 0xff;
1083 byte2 = (value >> 8) & 0xff;
1084 byte1 = value & 0xff;
1085
1086 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1087 return( swapped );
1088}
1089
1097#define CPU_swap_u16( value ) \
1098 (((value&0xff) << 8) | ((value >> 8)&0xff))
1099
1100typedef uint32_t CPU_Counter_ticks;
1101
1102uint32_t _CPU_Counter_frequency( void );
1103
1104typedef CPU_Counter_ticks ( *SPARC_Counter_read )( void );
1105
1106/*
1107 * The SPARC processors supported by RTEMS have no built-in CPU counter
1108 * support. We have to use some hardware counter module for this purpose, for
1109 * example the GPTIMER instance used by the clock driver. The BSP must provide
1110 * an implementation of the CPU counter read function. This allows the use of
1111 * dynamic hardware enumeration.
1112 */
1113typedef struct {
1114 SPARC_Counter_read read_isr_disabled;
1115 SPARC_Counter_read read;
1116 volatile const CPU_Counter_ticks *counter_register;
1117 volatile const uint32_t *pending_register;
1118 uint32_t pending_mask;
1119 CPU_Counter_ticks accumulated;
1120 CPU_Counter_ticks interval;
1122
1123extern const SPARC_Counter _SPARC_Counter;
1124
1125static inline CPU_Counter_ticks _CPU_Counter_read( void )
1126{
1127 return ( *_SPARC_Counter.read )();
1128}
1129
1130static inline CPU_Counter_ticks _CPU_Counter_difference(
1131 CPU_Counter_ticks second,
1132 CPU_Counter_ticks first
1133)
1134{
1135 return second - first;
1136}
1137
1139typedef uintptr_t CPU_Uint32ptr;
1140
1141#endif /* ASM */
1142
1143#ifdef __cplusplus
1144}
1145#endif
1146
1147#endif
Basic Definitions.
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
const CPU_Trap_table_entry _CPU_Trap_slot_template
Definition: cpu.c:156
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
#define SPARC_PSR_PIL_MASK
Definition: sparc.h:127
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
uint32_t g4
Definition: cpu.h:587
uint32_t i1
Definition: cpu.h:597
uint32_t i3
Definition: cpu.h:601
SPARC_Minimum_stack_frame Stack_frame
Definition: cpu.h:573
uint32_t g1
Definition: cpu.h:581
uint32_t tpc
Definition: cpu.h:613
uint32_t g2
Definition: cpu.h:583
uint32_t i6_fp
Definition: cpu.h:607
uint32_t i2
Definition: cpu.h:599
uint32_t i7
Definition: cpu.h:609
uint32_t pc
Definition: cpu.h:577
uint32_t reserved_for_alignment
Definition: cpu.h:591
uint32_t y
Definition: cpu.h:611
uint32_t g7
Definition: cpu.h:593
uint32_t psr
Definition: cpu.h:575
uint32_t g5
Definition: cpu.h:589
uint32_t i5
Definition: cpu.h:605
uint32_t i0
Definition: cpu.h:595
uint32_t i4
Definition: cpu.h:603
uint32_t npc
Definition: cpu.h:579
uint32_t g3
Definition: cpu.h:585
Definition: cpu.h:627
uint32_t mov_vector_l3
Definition: cpu.h:635
uint32_t mov_psr_l0
uint32_t jmp_to_low_of_handler_plus_l4
Definition: cpu.h:633
uint32_t sethi_of_handler_to_l4
Definition: cpu.h:631
SPARC basic context.
Definition: cpu.h:194
double f24_f25
Definition: cpu.h:504
double f28_f29
Definition: cpu.h:508
uint32_t fsr
Definition: cpu.h:512
double f2_f3
Definition: cpu.h:482
double f0_f1
Definition: cpu.h:480
double f16_f17
Definition: cpu.h:496
double f4_f5
Definition: cpu.h:484
double f20_f21
Definition: cpu.h:500
double f26_f27
Definition: cpu.h:506
double f8_f9
Definition: cpu.h:488
double f30_f31
Definition: cpu.h:510
double f18_f19
Definition: cpu.h:498
double f10_f11
Definition: cpu.h:490
double f22_f23
Definition: cpu.h:502
double f6_f7
Definition: cpu.h:486
double f12_f13
Definition: cpu.h:492
double f14_f15
Definition: cpu.h:494
Thread register context.
uint32_t i4
Definition: cpu.h:354
uint32_t i5
Definition: cpu.h:356
uint32_t i3
Definition: cpu.h:352
uint32_t o6_sp
Definition: cpu.h:363
uint32_t g7
Definition: cpu.h:322
uint32_t l5
Definition: cpu.h:339
uint32_t g5
Definition: cpu.h:320
uint32_t i0
Definition: cpu.h:346
uint32_t psr
Definition: cpu.h:371
uint32_t l3
Definition: cpu.h:335
uint32_t l4
Definition: cpu.h:337
uint32_t o7
Definition: cpu.h:368
uint32_t l2
Definition: cpu.h:333
uint32_t i7
Definition: cpu.h:360
uint32_t i2
Definition: cpu.h:350
uint32_t i1
Definition: cpu.h:348
uint32_t l6
Definition: cpu.h:341
uint32_t i6_fp
Definition: cpu.h:358
uint32_t l7
Definition: cpu.h:343
double l0_and_l1
Definition: cpu.h:331
Definition: cpu.h:1113
Definition: cpu.h:170
uint32_t l7
Definition: cpu.h:186
uint32_t saved_arg5
Definition: cpu.h:221
uint32_t saved_arg4
Definition: cpu.h:219
uint32_t saved_arg1
Definition: cpu.h:213
uint32_t pad0
Definition: cpu.h:223
uint32_t i7
Definition: cpu.h:202
uint32_t i2
Definition: cpu.h:192
uint32_t l0
Definition: cpu.h:172
uint32_t l3
Definition: cpu.h:178
uint32_t l1
Definition: cpu.h:174
uint32_t i0
Definition: cpu.h:188
uint32_t i3
uint32_t saved_arg2
Definition: cpu.h:215
uint32_t i6_fp
Definition: cpu.h:200
uint32_t l2
Definition: cpu.h:176
void * structure_return_address
Definition: cpu.h:204
uint32_t saved_arg0
Definition: cpu.h:211
uint32_t i4
Definition: cpu.h:196
uint32_t l6
Definition: cpu.h:184
uint32_t saved_arg3
Definition: cpu.h:217
uint32_t i1
Definition: cpu.h:190
uint32_t l5
Definition: cpu.h:182
uint32_t i5
Definition: cpu.h:198
uint32_t l4
Definition: cpu.h:180
unsigned context
Definition: tlb.h:1
unsigned size
Definition: tte.h:1
