RTEMS 5.2
serial.h
1
8/*
9 * This file contains the TTY driver table definition
10 *
11 * This driver uses the termios pseudo driver.
12 *
13 * COPYRIGHT (c) 1989-1999.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef __LIBCHIP_SERIAL_h
22#define __LIBCHIP_SERIAL_h
23
24#include <termios.h>
25
26#include <rtems.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32/*
33 * Types for get and set register routines
34 */
35
42typedef uint8_t (*getRegister_f)(uintptr_t port, uint8_t reg);
43
51typedef void (*setRegister_f)(uintptr_t port, uint8_t reg, uint8_t value);
52
59typedef uint8_t (*getData_f)(uintptr_t port);
60
67typedef void (*setData_f)(uintptr_t port, uint8_t value);
68
76typedef struct _console_fns {
77 bool (*deviceProbe)(int minor);
78 int (*deviceFirstOpen)(int major, int minor, void *arg);
79 int (*deviceLastClose)(int major, int minor, void *arg);
80 int (*deviceRead)(int minor);
81 ssize_t (*deviceWrite)(int minor, const char *buf, size_t len);
82 void (*deviceInitialize)(int minor);
83 void (*deviceWritePolled)(int minor, char cChar);
84 int (*deviceSetAttributes)(int minor, const struct termios *t);
85 bool deviceOutputUsesInterrupts;
87
94typedef struct _console_flow {
95 int (*deviceStopRemoteTx)(int minor);
96 int (*deviceStartRemoteTx)(int minor);
98
99
104typedef enum {
105 SERIAL_MC68681, /* Motorola MC68681 or Exar 88681 */
106 SERIAL_NS16550, /* National Semiconductor NS16550 */
107 SERIAL_NS16550_WITH_FDR, /* National Semiconductor NS16550
108 with Fractional Divider Register (FDR) */
109 SERIAL_Z85C30, /* Zilog Z85C30 */
110 SERIAL_CUSTOM /* BSP specific driver */
112
117typedef struct _console_tbl {
119 const char *sDeviceName;
130 bool (*deviceProbe)(int minor);
149 uint32_t ulMargin;
157 uint32_t ulHysteresis;
166 uint32_t ulCtrlPort1;
170 uint32_t ulCtrlPort2;
172 uint32_t ulDataPort;
174 getRegister_f getRegister;
176 setRegister_f setRegister;
179 /* This is the routine used to write the data register (TX). */
180 setData_f setData;
182 uint32_t ulClock;
184 unsigned int ulIntVector;
186
190typedef struct _console_data {
191 void *termios_data;
192 volatile bool bActive;
196
205extern unsigned long Console_Port_Count;
206
215extern unsigned long Console_Configuration_Count;
216
221
222extern rtems_device_minor_number Console_Port_Minor;
223
229void bsp_console_select(void);
230
231#ifdef __cplusplus
232}
233#endif
234
235#endif
console_devs
Definition: serial.h:104
Definition: legacy-console.c:31
struct _console_data console_data
console_tbl ** Console_Port_Tbl
Definition: legacy-console.c:32
Definition: console-config.c:89
console_data * Console_Port_Data
Definition: legacy-console.c:33
struct _console_tbl console_tbl
uint8_t(* getData_f)(uintptr_t port)
Definition: serial.h:59
console_tbl Console_Configuration_Ports[]
Definition: console-config.c:68
Selects the minor number of the console device.
Definition: console_select.c:218
void(* setData_f)(uintptr_t port, uint8_t value)
Definition: serial.h:67
Definition: serial.h:190
void * pDeviceContext
Definition: serial.h:194
Definition: serial.h:94
Definition: serial.h:76
Definition: serial.h:117
uint32_t ulClock
Definition: serial.h:182
Definition: serial.h:176
void * pDeviceParams
Definition: serial.h:162
Definition: serial.h:166
uint32_t ulDataPort
Definition: serial.h:172
const console_flow * pDeviceFlow
Definition: serial.h:138
Definition: serial.h:184
uint32_t ulMargin
Definition: serial.h:149
Definition: serial.h:170
bool(* deviceProbe)(int minor)
Definition: serial.h:130
getData_f getData
Definition: serial.h:178
Definition: serial.h:157
Definition: serial.h:174
console_devs deviceType
Definition: serial.h:124
const console_fns * pDeviceFns
Definition: serial.h:126
const char * sDeviceName
Definition: serial.h:119
