RTEMS 5.2
rtems-rfs-buffer.h
1
11/*
12 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19
20#if !defined (_RTEMS_RFS_BUFFER_H_)
21#define _RTEMS_RFS_BUFFER_H_
22
23#include <errno.h>
24
27
33#if defined (__rtems__)
34#define RTEMS_RFS_USE_LIBBLOCK 1
35#endif
36
40#if RTEMS_RFS_USE_LIBBLOCK
41#include <rtems/bdbuf.h>
42#include <rtems/error.h>
43
46#define rtems_rfs_buffer_io_request rtems_rfs_buffer_bdbuf_request
47#define rtems_rfs_buffer_io_release rtems_rfs_buffer_bdbuf_release
48
52int rtems_rfs_buffer_bdbuf_request (rtems_rfs_file_system* fs,
54 bool read,
55 rtems_rfs_buffer** buffer);
59int rtems_rfs_buffer_bdbuf_release (rtems_rfs_buffer* handle,
60 bool modified);
61#else /* Device I/O */
62typedef uint32_t rtems_rfs_buffer_block;
63typedef struct _rtems_rfs_buffer
64{
67 void* buffer;
68 size_t size;
69 uint32_t references;
71#define rtems_rfs_buffer_io_request rtems_rfs_buffer_deviceio_request
72#define rtems_rfs_buffer_io_release rtems_rfs_buffer_deviceio_release
73
79 bool read,
80 rtems_rfs_buffer* buffer);
85 bool modified);
86#endif
87
92{
96 bool dirty;
97
103
108
110
114#define rtems_rfs_buffer_link(_h) (&(_h)->buffer->link)
115
119#define rtems_rfs_buffer_data(_h) ((void*)((_h)->buffer->buffer))
120
124#define rtems_rfs_buffer_size(_h) ((_h)->buffer->size)
125
129#define rtems_rfs_buffer_bnum(_h) ((_h)->bnum)
130
134#define rtems_rfs_buffer_dirty(_h) ((_h)->dirty)
135
139#define rtems_rfs_buffer_handle_has_block(_h) ((_h)->buffer ? true : false)
140
144#define rtems_rfs_buffer_mark_dirty(_h) ((_h)->dirty = true)
145
149#define rtems_rfs_buffer_refs(_h) ((_h)->buffer->references)
150
154#define rtems_rfs_buffer_refs_up(_h) ((_h)->buffer->references += 1)
155
159#define rtems_rfs_buffer_refs_down(_h) ((_h)->buffer->references -= 1)
160
176 bool read);
177
191
201static inline int
202rtems_rfs_buffer_handle_open (rtems_rfs_file_system* fs,
204{
205 handle->dirty = false;
206 handle->bnum = 0;
207 handle->buffer = NULL;
208 return 0;
209}
210
220static inline int
221rtems_rfs_buffer_handle_close (rtems_rfs_file_system* fs,
223{
225 handle->dirty = false;
226 handle->bnum = 0;
227 handle->buffer = NULL;
228 return 0;
229}
230
240int rtems_rfs_buffer_open (const char* name, rtems_rfs_file_system* fs);
241
251
261
272
282
283#endif
Block Device Buffer Management.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
RTEMS Error Reporting.
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:45
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
int rtems_rfs_buffer_handle_request(rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *handle, rtems_rfs_buffer_block block, bool read)
Definition: rtems-rfs-buffer.c:79
int rtems_rfs_buffers_release(rtems_rfs_file_system *fs)
Definition: rtems-rfs-buffer.c:466
Definition: rtems-rfs-buffer.h:62
int rtems_rfs_buffer_deviceio_release(rtems_rfs_buffer *handle, bool modified)
struct rtems_rfs_buffer_handle_t rtems_rfs_buffer_handle
int rtems_rfs_buffer_handle_release(rtems_rfs_file_system *fs, rtems_rfs_buffer_handle *handle)
Definition: rtems-rfs-buffer.c:201
int rtems_rfs_buffer_setblksize(rtems_rfs_file_system *fs, uint32_t size)
Definition: rtems-rfs-buffer.c:414
int rtems_rfs_buffer_deviceio_request(rtems_rfs_file_system *fs, rtems_rfs_buffer_block block, bool read, rtems_rfs_buffer *buffer)
int rtems_rfs_buffer_sync(rtems_rfs_file_system *fs)
Definition: rtems-rfs-buffer.c:379
int rtems_rfs_buffer_close(rtems_rfs_file_system *fs)
Definition: rtems-rfs-buffer.c:350
int rtems_rfs_buffer_open(const char *name, rtems_rfs_file_system *fs)
Definition: rtems-rfs-buffer.c:289
RTEMS File Systems Data Forward Declaration.
Manages the Trace and Debugging Features of the RTEMS RFS File System.
Definition: chain.h:68
Definition: rtems-rfs-buffer.h:64
Definition: rtems-rfs-file-system.h:116
Definition: bdbuf.h:309
Definition: rtems-rfs-buffer.h:92
rtems_rfs_buffer * buffer
Definition: rtems-rfs-buffer.h:107
bool dirty
Definition: rtems-rfs-buffer.h:96
rtems_rfs_buffer_block bnum
Definition: rtems-rfs-buffer.h:102
unsigned size
Definition: tte.h:1
