RTEMS 5.2
Intel I386 Interrupt Macros. More...
Interrupt Level Macros | |
| #define | i386_disable_interrupts(_level) |
| #define | i386_enable_interrupts(_level) |
| #define | i386_flash_interrupts(_level) |
| #define | i386_get_interrupt_level(_level) |
Typedefs | |
| typedef void(* | rtems_raw_irq_hdl) (void) |
| typedef void(* | rtems_raw_irq_enable) (const struct __rtems_raw_irq_connect_data__ *) |
| typedef void(* | rtems_raw_irq_disable) (const struct __rtems_raw_irq_connect_data__ *) |
| typedef int(* | rtems_raw_irq_is_enabled) (const struct __rtems_raw_irq_connect_data__ *) |
Formerly contained in and extracted from libcpu/i386/cpu.h
