RTEMS 5.2
TMS570 Board Support Package. More...
Modules | |
| System Clocks | |
| System clocks. | |
Files | |
| file | clock.c |
| clock functions definitions. | |
| file | printk-support.c |
| definitions of serial line for debugging. | |
| file | tms570-sci.c |
| Serial communication interface (SCI) functions definitions. | |
| file | bsp.h |
| Global BSP definitions. | |
| file | irq.h |
| TMS570 interrupt definitions. | |
| file | system-clocks.h |
| System clocks. | |
| file | tms570-pinmux.h |
| I/O Multiplexing Module (IOMM) basic support. | |
| file | tms570-pins.h |
| Select pin mapping according to selected chip. Defaults to TMS570LS3137ZWT for now. | |
| file | tms570-pom.h |
| Parameter Overlay Module (POM) header file. | |
| file | tms570-rti.h |
| Real Time Interrupt module (RTI) header file. | |
| file | tms570-sci-driver.h |
| Declaration of serial's driver inner structure. | |
| file | tms570-sci.h |
| Serial Communication Interface (SCI) header file. | |
| file | tms570-vim.h |
| Vectored Interrupt Module (VIM) header file. | |
| file | tms570_selftest.h |
| Definition of TMS570 selftest error codes, addresses and functions. | |
| file | tms570_selftest_parity.h |
| Check of module parity based protection logic to work. | |
| file | tms570lc4357-pins.h |
| Specification of individual pins mapping to the package. | |
| file | tms570ls3137zwt-pins.h |
| file | irq.c |
| TMS570 interrupt support functions definitions. | |
| file | bspreset.c |
| Reset code. | |
| file | bspstart.c |
| Startup code. | |
| file | bspstarthooks.c |
| First configurations and initializations to the correct functionality of the board. | |
| file | init_emif_sdram.c |
| Initialization of external memory/SDRAM interface. | |
| file | init_esm.c |
| Error signaling module initialization. | |
| file | init_pinmux.c |
| Initialize pin multiplexers. | |
| file | pinmux.c |
| file | tms570-pom.c |
| TMS570 Parameter Overlay Module functions definitions. | |
| file | tms570_selftest.c |
| TMS570 selftest support functions implementation. | |
| file | tms570_selftest_par_can.c |
| Test CAN module parity based protection logic to work. | |
| file | tms570_selftest_par_mibspi.c |
| Test MibSPI module parity based protection logic to work. | |
| file | tms570_selftest_par_std.c |
| Generic parity based protection logic check applicable to HETx, HTUx, ADC, DMA and VIM. | |
| file | tms570_selftest_parity.c |
| file | tms570_tcram_tests.c |
| TCRAM selftest function. | |
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_OSCILATOR_CLOCK 8000000 |
| #define | BSP_PLL_OUT_CLOCK 160000000 |
