RTEMS 5.2
- r -
- RTC_Table : rtc-config.c
- rtems_ada_self : threadimpl.h
- rtems_bdbuf_configuration : bdbuf.h
- rtems_fb_default_mode : fb_vesa_rm.c, fb_default_mode.h
- rtems_filesystem_default_pathconf : libio.h, mount.c
- rtems_filesystem_global_location_null : libio_.h, __usrenv.c
- rtems_filesystem_handlers_default : libio.h, default_handlers.c
- rtems_filesystem_operations_default : libio.h, default_ops.c
- rtems_filesystem_table : libio.h
- rtems_flashdisk_configuration : flashdisk.h
- rtems_flashdisk_configuration_size : flashdisk.h
- rtems_interrupt_mask : modes.h, modes.c
- RTEMS_Malloc_Heap : malloc.h, malloc_initialize.c
- rtems_minimum_stack_size : stack.h
- rtems_nvdisk_configuration : nvdisk.h
- rtems_nvdisk_configuration_size : nvdisk.h
- rtems_nvdisk_sram_handlers : nvdisk-sram.h, nvdisk-sram.c
- rtems_ramdisk_configuration : ramdisk.h
- rtems_ramdisk_configuration_size : ramdisk.h
- rtems_rfs_ops : rtems-rfs-rtems.c
- rtems_rfs_rtems_dir_handlers : rtems-rfs-rtems-dir.c, rtems-rfs-rtems.h
- rtems_rfs_rtems_link_handlers : rtems-rfs-rtems.c, rtems-rfs-rtems.h
- rtems_termios_baud_table : termiostypes.h, termios_baudtable.c
