RTEMS 5.2
Global BSP definitions. More...
#include <bspopts.h>#include <rtems.h>#include <libcpu/powerpc-utility.h>#include <bsp/tictac.h>#include <bsp/linker-symbols.h>#include <bsp/default-initial-extension.h>Go to the source code of this file.
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | MPC55XX_PERIPHERAL_CLOCK (MPC55XX_SYSTEM_CLOCK / MPC55XX_SYSTEM_CLOCK_DIVIDER) |
| #define | BSP_Convert_decrementer(_value) (((unsigned long long) (_value)) / ((unsigned long long)bsp_clicks_per_usec)) |
| Convert Decrementer ticks to microseconds. | |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH smsc9218i_attach_detach |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| #define | BSP_DSRAM_SECTION __attribute__((section(".bsp_dsram"))) |
| #define | BSP_SYSRAM_SECTION __attribute__((section(".bsp_sysram"))) |
| rtems_status_code | mpc55xx_sd_card_init (bool mount) |
| int | smsc9218i_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| rtems_status_code | bsp_register_i2c (void) |
| void | bsp_restart (void *addr) |
| void * | bsp_idle_thread (uintptr_t arg) |
| Optimized idle task. More... | |
| unsigned int | bsp_clock_speed |
| System clock frequency. | |
| uint32_t | bsp_clicks_per_usec |
| Time base clicks per micro second. | |
