RTEMS 5.2
Global BSP definitions. More...
#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <rtems/bspIo.h>#include <mvme16x_hw.h>Go to the source code of this file.
| struct | memc040_regs_ |
| struct | cd2401_regs_ |
| #define | memc040_1 ((memc040_regs * const) 0xFFF43000) |
| #define | memc040_2 ((memc040_regs * const) 0xFFF43100) |
| #define | cd2401 ((cd2401_regs * const) 0xFFF45000) |
| #define | CD2401_CLK_RATE 20000000 |
| #define | EXTERN extern |
Typedefs | |
| typedef volatile struct memc040_regs_ | memc040_regs |
| typedef volatile struct cd2401_regs_ | cd2401_regs |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. More... | |
| void * | M68Kvec [] |
