RTEMS 5.2
Global BSP definitions. More...
#include <mcf5272/mcf5272.h>#include <bspopts.h>#include <rtems.h>#include <bsp/default-initial-extension.h>Go to the source code of this file.
| #define | BSP_MEM_ADDR_SRAM 0x20000000 |
| #define | BSP_MEM_SIZE_SRAM 4096 |
| #define | BSP_MEM_ADDR_SDRAM 0x00000000 |
| #define | BSP_MEM_MASK_SDRAM 0x01ffffff |
| #define | BSP_MEM_SIZE_SDRAM (32 * 1024 * 1024) |
| #define | BSP_MBAR 0x10000000 |
| #define | BSP_RAMBAR BSP_MEM_ADDR_SRAM |
| #define | BSP_INTVEC_INT1 65 |
| #define | BSP_INTVEC_INT2 66 |
| #define | BSP_INTVEC_INT3 67 |
| #define | BSP_INTVEC_INT4 68 |
| #define | BSP_INTVEC_TMR0 69 |
| #define | BSP_INTVEC_TMR1 70 |
| #define | BSP_INTVEC_TMR2 71 |
| #define | BSP_INTVEC_TMR3 72 |
| #define | BSP_INTVEC_UART1 73 |
| #define | BSP_INTVEC_UART2 74 |
| #define | BSP_INTVEC_PLIP 75 |
| #define | BSP_INTVEC_PLIA 76 |
| #define | BSP_INTVEC_USB0 77 |
| #define | BSP_INTVEC_USB1 78 |
| #define | BSP_INTVEC_USB2 79 |
| #define | BSP_INTVEC_USB3 80 |
| #define | BSP_INTVEC_USB4 81 |
| #define | BSP_INTVEC_USB5 82 |
| #define | BSP_INTVEC_USB6 83 |
| #define | BSP_INTVEC_USB7 84 |
| #define | BSP_INTVEC_DMA 85 |
| #define | BSP_INTVEC_ERX 86 |
| #define | BSP_INTVEC_ETX 87 |
| #define | BSP_INTVEC_ENTC 88 |
| #define | BSP_INTVEC_QSPI 89 |
| #define | BSP_INTVEC_INT5 90 |
| #define | BSP_INTVEC_INT6 91 |
| #define | BSP_INTVEC_SWTO 92 |
| #define | BSP_INTLVL_INT1 1 |
| #define | BSP_INTLVL_INT2 1 |
| #define | BSP_INTLVL_INT3 1 |
| #define | BSP_INTLVL_INT4 1 |
| #define | BSP_INTLVL_TMR0 1 |
| #define | BSP_INTLVL_TMR1 1 |
| #define | BSP_INTLVL_TMR2 1 |
| #define | BSP_INTLVL_TMR3 1 |
| #define | BSP_INTLVL_UART1 1 |
| #define | BSP_INTLVL_UART2 1 |
| #define | BSP_INTLVL_PLIP 1 |
| #define | BSP_INTLVL_PLIA 1 |
| #define | BSP_INTLVL_USB0 1 |
| #define | BSP_INTLVL_USB1 1 |
| #define | BSP_INTLVL_USB2 1 |
| #define | BSP_INTLVL_USB3 1 |
| #define | BSP_INTLVL_USB4 1 |
| #define | BSP_INTLVL_USB5 1 |
| #define | BSP_INTLVL_USB6 1 |
| #define | BSP_INTLVL_USB7 1 |
| #define | BSP_INTLVL_DMA 1 |
| #define | BSP_INTLVL_ERX 1 |
| #define | BSP_INTLVL_ETX 1 |
| #define | BSP_INTLVL_ENTC 1 |
| #define | BSP_INTLVL_QSPI 1 |
| #define | BSP_INTLVL_INT5 1 |
| #define | BSP_INTLVL_INT6 1 |
| #define | BSP_INTLVL_SWTO 1 |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_enet_driver_attach |
| #define | BSP_SYSTEM_FREQUENCY (66 * 1000 * 1000) |
| #define | rtems_bsp_delay(microseconds) |
| #define | RTC_DRIVER_TABLE_ENTRY { rtc_initialize, NULL, NULL, NULL, NULL, NULL } |
| int | rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config) |
| rtems_device_driver | rtc_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. More... | |
| void | init5272 (void) |
| rtems_isr_entry | M68Kvec [] |
| rtems_isr(* | rtems_clock_hook )(rtems_vector_number) |
