RTEMS
5.1
video core support. More...
#include <string.h>Go to the source code of this file.
| struct | bcm2835_mbox_buf_hdr |
| Buffer Header. More... | |
| struct | bcm2835_mbox_tag_hdr |
| Tag Header. More... | |
| struct | bcm2835_mbox_tag_get_fw_rev |
| struct | bcm2835_mbox_tag_get_board_spec |
| struct | bcm2835_mbox_tag_get_board_serial |
| struct | bcm2835_mbox_tag_get_arm_memory |
| struct | bcm2835_mbox_tag_get_vc_memory |
| struct | bcm2835_mbox_tag_get_clock_rate |
| struct | bcm2835_mbox_tag_get_cmd_line |
| struct | bcm2835_mbox_tag_get_power_state |
| struct | bcm2835_mbox_tag_power_state |
| struct | bcm2835_mbox_tag_allocate_buffer |
| struct | bcm2835_mbox_tag_display_size |
| struct | bcm2835_mbox_tag_virtual_size |
| struct | bcm2835_mbox_tag_depth |
| struct | bcm2835_mbox_tag_pixel_order |
| struct | bcm2835_mbox_tag_alpha_mode |
| struct | bcm2835_mbox_tag_get_pitch |
| struct | bcm2835_mbox_tag_virtual_offset |
| struct | bcm2835_mbox_tag_overscan |
Mailbox Property tags (ARM <-> VC) | |
| #define | BCM2835_MBOX_BUF_CODE_PROCESS_REQUEST 0x00000000 |
| #define | BCM2835_MBOX_BUF_CODE_REQUEST_SUCCEED 0x80000000 |
| #define | BCM2835_MBOX_BUF_CODE_REQUEST_PARSING_ERROR 0x80000001 |
| #define | BCM2835_MBOX_TAG_VAL_LEN_REQUEST 0x00000000 |
| #define | BCM2835_MBOX_TAG_VAL_LEN_RESPONSE 0x80000000 |
| #define | BCM2835_MBOX_TAG_REPLY_IS_SET(_t_) ( ( _t_ )->tag_hdr.val_len & 0x80000000 ) |
| #define | BCM2835_MBOX_INIT_BUF(_m_) |
| #define | BCM2835_MBOX_INIT_TAG(_t_, _id_) |
| #define | BCM2835_MBOX_INIT_TAG_NO_REQ(_t_, _id_) |
| #define | BCM2835_MBOX_BUF_ALIGN_ATTRIBUTE __attribute__( ( aligned( 64 ) ) ) |
| #define | BCM2835_MAILBOX_TAG_FIRMWARE_REVISION 0x00000001 |
| #define | BCM2835_MAILBOX_TAG_GET_BOARD_MODEL 0x00010001 |
| #define | BCM2835_MAILBOX_TAG_GET_BOARD_VERSION 0x00010002 |
| #define | BCM2835_MAILBOX_BOARD_V_B_I2C0_2 0x2 |
| #define | BCM2835_MAILBOX_BOARD_V_B_I2C0_3 0x3 |
| #define | BCM2835_MAILBOX_BOARD_V_B_I2C1_4 0x4 |
| #define | BCM2835_MAILBOX_BOARD_V_B_I2C1_5 0x5 |
| #define | BCM2835_MAILBOX_BOARD_V_B_I2C1_6 0x6 |
| #define | BCM2835_MAILBOX_BOARD_V_A_7 0x7 |
| #define | BCM2835_MAILBOX_BOARD_V_A_8 0x8 |
| #define | BCM2835_MAILBOX_BOARD_V_A_9 0x9 |
| #define | BCM2835_MAILBOX_BOARD_V_B_REV2_d 0xd |
| #define | BCM2835_MAILBOX_BOARD_V_B_REV2_e 0xe |
| #define | BCM2835_MAILBOX_BOARD_V_B_REV2_f 0xf |
| #define | BCM2835_MAILBOX_BOARD_V_B_PLUS 0x10 |
| #define | BCM2835_MAILBOX_BOARD_V_CM 0x11 |
| #define | BCM2835_MAILBOX_BOARD_V_A_PLUS 0x12 |
| #define | BCM2835_MAILBOX_TAG_GET_BOARD_MAC 0x00010003 |
| #define | BCM2835_MAILBOX_TAG_GET_BOARD_SERIAL 0x00010004 |
| #define | BCM2835_MAILBOX_TAG_GET_ARM_MEMORY 0x00010005 |
| #define | BCM2835_MAILBOX_TAG_GET_VC_MEMORY 0x00010006 |
| #define | BCM2835_MAILBOX_TAG_GET_CLOCKS 0x00010007 |
| #define | BCM2835_MAILBOX_TAG_GET_CMD_LINE 0x00050001 |
| #define | BCM2835_MAILBOX_TAG_GET_DMA_CHANNELS 0x00060001 |
| #define | BCM2835_MAILBOX_POWER_UDID_SD_Card 0x00000000 |
| #define | BCM2835_MAILBOX_POWER_UDID_UART0 0x00000001 |
| #define | BCM2835_MAILBOX_POWER_UDID_UART1 0x00000002 |
| #define | BCM2835_MAILBOX_POWER_UDID_USB_HCD 0x00000003 |
| #define | BCM2835_MAILBOX_POWER_UDID_I2C0 0x00000004 |
| #define | BCM2835_MAILBOX_POWER_UDID_I2C1 0x00000005 |
| #define | BCM2835_MAILBOX_POWER_UDID_I2C2 0x00000006 |
| #define | BCM2835_MAILBOX_POWER_UDID_SPI 0x00000007 |
| #define | BCM2835_MAILBOX_POWER_UDID_CCP2TX 0x00000008 |
| #define | BCM2835_MAILBOX_TAG_GET_POWER_STATE 0x00020001 |
| #define | BCM2835_MAILBOX_POWER_STATE_RESP_ON (1 << 0) |
| #define | BCM2835_MAILBOX_POWER_STATE_RESP_NODEV (1 << 1) |
| #define | BCM2835_MAILBOX_TAG_GET_TIMING 0x00020002 |
| #define | BCM2835_MAILBOX_TAG_SET_POWER_STATE 0x00028001 |
| #define | BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON (1 << 0) |
| #define | BCM2835_MAILBOX_SET_POWER_STATE_REQ_WAIT (1 << 1) |
| #define | BCM2835_MAILBOX_UCID_CLOCK_RESERVED 0x000000000 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_EMMC 0x000000001 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_UART 0x000000002 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_ARM 0x000000003 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_CORE 0x000000004 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_V3D 0x000000005 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_H264 0x000000006 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_ISP 0x000000007 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_SDRAM 0x000000008 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_PIXEL 0x000000009 |
| #define | BCM2835_MAILBOX_UCID_CLOCK_PWM 0x00000000a |
| #define | BCM2835_MAILBOX_TAG_GET_CLOCK_STATE 0x00030001 |
| #define | BCM2835_MAILBOX_TAG_SET_CLOCK_STATE 0x00038001 |
| #define | BCM2835_MAILBOX_TAG_GET_CLOCK_RATE 0x00030002 |
| #define | BCM2835_MAILBOX_TAG_SET_CLOCK_RATE 0x00038002 |
| #define | BCM2835_MAILBOX_TAG_GET_MAX_CLOCK_RATE 0x00030004 |
| #define | BCM2835_MAILBOX_TAG_GET_MIN_CLOCK_RATE 0x00030007 |
| #define | BCM2835_MAILBOX_TAG_GET_TRUBO 0x00030009 |
| #define | BCM2835_MAILBOX_TAG_SET_TURBO 0x00038009 |
| #define | BCM2835_MAILBOX_TAG_GET_DOMAIN_STATE 0x00030030 |
| #define | BCM2835_MAILBOX_TAG_SET_DOMAIN_STATE 0x00038030 |
| #define | BCM2835_MAILBOX_VOLTAGE_RESERVED_UVID 0x000000000 |
| #define | BCM2835_MAILBOX_VOLTAGE_CORE_UVID 0x000000001 |
| #define | BCM2835_MAILBOX_VOLTAGE_SDRAM_C_UVID 0x000000002 |
| #define | BCM2835_MAILBOX_VOLTAGE_SDRAM_P_UVID 0x000000003 |
| #define | BCM2835_MAILBOX_VOLTAGE_SDRAM_I_UVID 0x000000004 |
| #define | BCM2835_MAILBOX_TAG_GET_VOLTAGE 0x00030003 |
| #define | BCM2835_MAILBOX_TAG_SET_VOLTAGE 0x00038003 |
| #define | BCM2835_MAILBOX_TAG_GET_MAX_VOLTAGE 0x00030005 |
| #define | BCM2835_MAILBOX_TAG_GET_MIN_VOLTAGE 0x00030008 |
| #define | BCM2835_MAILBOX_TAG_GET_TEMPERATURE 0x00030006 |
| #define | BCM2835_MAILBOX_TAG_GET_MAX_TEMPERATURE 0x0003000a |
| #define | BCM2835_MAILBOX_TAG_ALLOCATE_MEMORY 0x0003000c |
| #define | BCM2835_MAILBOX_TAG_LOCK_MEMORY 0x0003000d |
| #define | BCM2835_MAILBOX_TAG_UNLOCK_MEMORY 0x0003000e |
| #define | BCM2835_MAILBOX_TAG_RELEASE_MEMORY 0x0003000f |
| #define | BCM2835_MAILBOX_TAG_EXECUTE_CODE 0x00030010 |
| #define | BCM2835_MAILBOX_TAG_GET_DISPMANX_RESOURCE_MEM_HANDLE 0x00030014 |
| #define | BCM2835_MAILBOX_TAG_GET_EDID_BLOCK 0x00030020 |
| #define | BCM2835_MAILBOX_TAG_ALLOCATE_BUFFER 0x00040001 |
| #define | BCM2835_MAILBOX_TAG_RELEASE_BUFFER 0x00048001 |
| #define | BCM2835_MAILBOX_TAG_BLANK_SCREEN 0x00040002 |
| #define | BCM2835_MAILBOX_TAG_GET_DISPLAY_SIZE 0x00040003 |
| #define | BCM2835_MAILBOX_TAG_TEST_DISPLAY_SIZE 0x00044003 |
| #define | BCM2835_MAILBOX_TAG_SET_DISPLAY_SIZE 0x00048003 |
| #define | BCM2835_MAILBOX_TAG_GET_VIRTUAL_SIZE 0x00040004 |
| #define | BCM2835_MAILBOX_TAG_TEST_VIRTUAL_SIZE 0x00044004 |
| #define | BCM2835_MAILBOX_TAG_SET_VIRTUAL_SIZE 0x00048004 |
| #define | BCM2835_MAILBOX_TAG_GET_DEPTH 0x00040005 |
| #define | BCM2835_MAILBOX_TAG_TEST_DEPTH 0x00044005 |
| #define | BCM2835_MAILBOX_TAG_SET_DEPTH 0x00048005 |
| #define | BCM2835_MAILBOX_TAG_GET_PIXEL_ORDER 0x00040006 |
| #define | BCM2835_MAILBOX_TAG_TEST_PIXEL_ORDER 0x00044006 |
| #define | BCM2835_MAILBOX_TAG_SET_PIXEL_ORDER 0x00048006 |
| #define | BCM2835_MAILBOX_PIXEL_ORDER_BGR 0 |
| #define | BCM2835_MAILBOX_PIXEL_ORDER_RGB 1 |
| #define | BCM2835_MAILBOX_TAG_GET_ALPHA_MODE 0x00040007 |
| #define | BCM2835_MAILBOX_TAG_TEST_ALPHA_MODE 0x00044007 |
| #define | BCM2835_MAILBOX_TAG_SET_ALPHA_MODE 0x00048007 |
| #define | BCM2835_MAILBOX_ALPHA_MODE_0_OPAQUE 0 |
| #define | BCM2835_MAILBOX_ALPHA_MODE_0_TRANSPARENT 1 |
| #define | BCM2835_MAILBOX_ALPHA_MODE_IGNORED 2 |
| #define | BCM2835_MAILBOX_TAG_GET_PITCH 0x00040008 |
| #define | BCM2835_MAILBOX_TAG_GET_VIRTUAL_OFFSET 0x00040009 |
| #define | BCM2835_MAILBOX_TAG_TEST_VIRTUAL_OFFSET 0x00044009 |
| #define | BCM2835_MAILBOX_TAG_SET_VIRTUAL_OFFSET 0x00048009 |
| #define | BCM2835_MAILBOX_TAG_GET_OVERSCAN 0x0004000a |
| #define | BCM2835_MAILBOX_TAG_TEST_OVERSCAN 0x0004400a |
| #define | BCM2835_MAILBOX_TAG_SET_OVERSCAN 0x0004800a |
| #define | BCM2835_MAILBOX_TAG_GET_PALETTE 0x0004000b |
| #define | BCM2835_MAILBOX_TAG_TEST_PALETTE 0x0004400b |
| #define | BCM2835_MAILBOX_TAG_SET_PALETTE 0x0004800b |
| #define | BCM2835_MAILBOX_TAG_SET_CURSOR_INFO 0x00008011 |
| #define | BCM2835_MAILBOX_TAG_SET_CURSOR_STATE 0x00008010 |
video core support.
1.8.15
