| void | _Thread_queue_Enqueue_do_nothing_extra (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Does nothing. More...
| void | _Thread_queue_Add_timeout_ticks (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds timeout ticks of the queue to the thread. More...
| void | _Thread_queue_Add_timeout_monotonic_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds a monotonic timespec to the thread and sets the watchdog header to monotonic. More...
| void | _Thread_queue_Add_timeout_realtime_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context) |
| | Adds a monotonic timespec to the thread and sets the watchdog header to realtime. More...
| void | _Thread_queue_Deadlock_status (Thread_Control *the_thread) |
| | Sets the thread wait return code to STATUS_DEADLOCK. More...
| void | _Thread_queue_Deadlock_fatal (Thread_Control *the_thread) |
| | Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_initialize (Thread_queue_Context *queue_context) |
| | Initializes a thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_thread_state (Thread_queue_Context *queue_context, States_Control thread_state) |
| | Sets the thread state for the thread to enqueue in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_timeout_ticks (Thread_queue_Context *queue_context, Watchdog_Interval ticks) |
| | Sets the timeout ticks in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_timeout_argument (Thread_queue_Context *queue_context, const void *arg) |
| | Sets the timeout argument in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_enqueue_callout (Thread_queue_Context *queue_context, Thread_queue_Enqueue_callout enqueue_callout) |
| | Sets the enqueue callout in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_enqueue_do_nothing_extra (Thread_queue_Context *queue_context) |
| | Sets the do nothing enqueue callout in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_enqueue_timeout_ticks (Thread_queue_Context *queue_context, Watchdog_Interval ticks) |
| | Sets the enqueue callout to add a relative monotonic timeout in ticks. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec (Thread_queue_Context *queue_context, const struct timespec *abstime) |
| | Sets the enqueue callout to add an absolute monotonic timeout in timespec format. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_enqueue_timeout_realtime_timespec (Thread_queue_Context *queue_context, const struct timespec *abstime) |
| | Sets the enqueue callout to add an absolute realtime timeout in timespec format. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_deadlock_callout (Thread_queue_Context *queue_context, Thread_queue_Deadlock_callout deadlock_callout) |
| | Sets the deadlock callout in the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_clear_priority_updates (Thread_queue_Context *queue_context) |
| | Clears the priority update count of the thread queue context. More...
| RTEMS_INLINE_ROUTINE size_t | _Thread_queue_Context_save_priority_updates (Thread_queue_Context *queue_context) |
| | Returns the priority update count of the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_restore_priority_updates (Thread_queue_Context *queue_context, size_t update_count) |
| | Sets the priority update count of the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_add_priority_update (Thread_queue_Context *queue_context, Thread_Control *the_thread) |
| | Adds a priority update of the thread to the thread queue context. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Context_set_ISR_level (Thread_queue_Context *queue_context, ISR_Level level) |
| | Sets the thread queue context ISR level. More...
| RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Thread_queue_Dispatch_disable (Thread_queue_Context *queue_context) |
| | Disables dispatching in a critical section. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Heads_initialize (Thread_queue_Heads *heads) |
| | Initializes the thread queue heads. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Queue_initialize (Thread_queue_Queue *queue, const char *name) |
| | Initializes the thread queue queue with the given name. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Queue_do_acquire_critical (Thread_queue_Queue *queue, ISR_lock_Context *lock_context) |
| | Acquires the thread queue queue in a critical section. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Queue_release_critical (Thread_queue_Queue *queue, ISR_lock_Context *lock_context) |
| | Releases the thread queue queue in a critical section. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Queue_release (Thread_queue_Queue *queue, ISR_lock_Context *lock_context) |
| | Releases the thread queue queue and enables interrupts. More...
| size_t | _Thread_queue_Queue_get_name_and_id (const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id) |
| | Copies the thread queue name to the specified buffer. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Do_acquire_critical (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context) |
| | Acquires the thread queue control in a critical section. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Acquire_critical (Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context) |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Acquire (Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context) |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Do_release_critical (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context) |
| | Checks if the thread queue control is the owner of the lock. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Release_critical (Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context) |
| | Releases the thread queue control in a critical section. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Release (Thread_queue_Control *the_thread_queue, Thread_queue_Context *queue_context) |
| | Releases the thread queue control and enables interrupts. More...
| Thread_Control * | _Thread_queue_Do_dequeue (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations) |
| | Dequeues the first thread waiting on the thread queue and returns it. More...
| void | _Thread_queue_Enqueue (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Blocks the thread and places it on the thread queue. More...
| bool | _Thread_queue_Extract_locked (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock. More...
| void | _Thread_queue_Unblock_critical (bool unblock, Thread_queue_Queue *queue, Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| | Unblocks the thread which was on the thread queue before. More...
| void | _Thread_queue_Extract_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context) |
| | Extracts the thread from the thread queue and unblocks it. More...
| void | _Thread_queue_Extract (Thread_Control *the_thread) |
| | Extracts thread from thread queue. More...
| void | _Thread_queue_Extract_with_proxy (Thread_Control *the_thread) |
| | Extracts the_thread from the_thread_queue. More...
| void | _Thread_queue_Surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations) |
| | Surrenders the thread queue previously owned by the thread to the first enqueued thread. More...
| RTEMS_INLINE_ROUTINE bool | _Thread_queue_Is_empty (const Thread_queue_Queue *queue) |
| | Checks if the thread queue queue is empty. More...
| RTEMS_INLINE_ROUTINE Thread_Control * | _Thread_queue_First_locked (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations) |
| | Returns the first thread on the thread queue if it exists, otherwise NULL. More...
| Thread_Control * | _Thread_queue_First (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations) |
| Thread_Control * | _Thread_queue_Flush_default_filter (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Default thread queue flush filter function. More...
| Thread_Control * | _Thread_queue_Flush_status_unavailable (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Status unavailable thread queue flush filter function. More...
| Thread_Control * | _Thread_queue_Flush_status_object_was_deleted (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context) |
| | Status object was deleted thread queue flush filter function. More...
| size_t | _Thread_queue_Flush_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context) |
| | Unblocks all threads enqueued on the thread queue. More...
| void | _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, const char *name) |
| | Initializes the thread queue control to the given name. More...
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Destroy (Thread_queue_Control *the_thread_queue) |
| | Destroys the thread queue. More...
| void | _Thread_queue_Object_initialize (Thread_queue_Control *the_thread_queue) |
| | Initializes a thread queue embedded in an object with identifier. More...
Constants and Structures Associated with the Manipulation of Objects.
This include file contains all the constants and structures associated with the manipulation of objects.
