RTEMS
5.1
Data Fields | |
| rtems_status_code(* | init )(rtems_libi2c_bus_t *bushdl) |
| rtems_status_code(* | send_start )(rtems_libi2c_bus_t *bushdl) |
| rtems_status_code(* | send_stop )(rtems_libi2c_bus_t *bushdl) |
| rtems_status_code(* | send_addr )(rtems_libi2c_bus_t *bushdl, uint32_t addr, int rw) |
| int(* | read_bytes )(rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes) |
| int(* | write_bytes )(rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes) |
| int(* | ioctl )(rtems_libi2c_bus_t *bushdl, int cmd, void *buffer) |
1.8.15
