struct arpcom | arpcom |
lpc_eth_state | state |
struct rtems_mdio_info | mdio |
uint32_t | anlpar |
rtems_id | receive_task |
rtems_id | transmit_task |
unsigned | rx_unit_count |
unsigned | tx_unit_count |
volatile lpc_eth_transfer_descriptor * | rx_desc_table |
volatile lpc_eth_receive_status * | rx_status_table |
struct mbuf ** | rx_mbuf_table |
volatile lpc_eth_transfer_descriptor * | tx_desc_table |
volatile uint32_t * | tx_status_table |
void * | tx_buf_table |
unsigned | received_frames |
unsigned | receive_interrupts |
unsigned | transmitted_frames |
unsigned | transmit_interrupts |
unsigned | receive_drop_errors |
unsigned | receive_overrun_errors |
unsigned | receive_fragment_errors |
unsigned | receive_crc_errors |
unsigned | receive_symbol_errors |
unsigned | receive_length_errors |
unsigned | receive_alignment_errors |
unsigned | receive_no_descriptor_errors |
unsigned | receive_fatal_errors |
unsigned | transmit_underrun_errors |
unsigned | transmit_late_collision_errors |
unsigned | transmit_excessive_collision_errors |
unsigned | transmit_excessive_defer_errors |
unsigned | transmit_no_descriptor_errors |
unsigned | transmit_overflow_errors |
unsigned | transmit_fatal_errors |
uint32_t | phy_id |
int | phy |
rtems_vector_number | interrupt_number |
rtems_id | control_task |
