void * | fill [2] |
volatile u_int16_t | cb_status |
volatile u_int16_t | cb_command |
volatile u_int32_t | link_addr |
volatile u_int | byte_count:6 |
volatile u_int volatile u_int | rx_fifo_limit:2:4 |
volatile u_int volatile u_int | tx_fifo_limit:3 |
volatile u_int volatile u_int volatile u_int8_t | adaptive_ifs:1 |
volatile u_int | mwi_enable:1 |
volatile u_int | type_enable:1 |
volatile u_int | read_align_en:1 |
volatile u_int | end_wr_on_cl:1 |
volatile u_int volatile u_int | rx_dma_bytecount:4:7 |
volatile u_int volatile u_int volatile u_int | tx_dma_bytecount:1:7 |
volatile u_int volatile u_int volatile u_int | dma_mbce:1 |
volatile u_int | late_scb:1 |
volatile u_int | direct_dma_dis:1 |
volatile u_int | tno_int_or_tco_en:1 |
volatile u_int | ci_int:1 |
volatile u_int | ext_txcb_dis:1 |
volatile u_int | ext_stats_dis:1 |
volatile u_int | keep_overrun_rx:1 |
volatile u_int | save_bf:1 |
volatile u_int | disc_short_rx:1 |
volatile u_int | underrun_retry:2 |
volatile u_int | two_frames:1 |
volatile u_int | dyn_tbd:1 |
volatile u_int | mediatype:1 |
volatile u_int | csma_dis:1 |
volatile u_int | tcp_udp_cksum:1 |
volatile u_int | vlan_tco:1 |
volatile u_int | link_wake_en:1 |
volatile u_int | arp_wake_en:1 |
volatile u_int | mc_wake_en:1 |
volatile | u_int:3 |
volatile | nsai:1 |
volatile | preamble_length:2 |
volatile | loopback:2 |
volatile u_int | linear_priority:3 |
volatile u_int volatile u_int | linear_pri_mode:5:1 |
volatile u_int volatile u_int | interfrm_spacing:4 |
volatile u_int | promiscuous:1 |
volatile u_int | bcast_disable:1 |
volatile u_int | wait_after_win:1 |
volatile u_int | ignore_ul:1 |
volatile u_int | crc16_en:1 |
volatile u_int | crscdt:1 |
volatile u_int | fc_delay_lsb:8 |
volatile u_int | fc_delay_msb:8 |
volatile u_int | stripping:1 |
volatile u_int | padding:1 |
volatile u_int | rcv_crc_xfer:1 |
volatile u_int | long_rx_en:1 |
volatile u_int | pri_fc_thresh:3 |
volatile u_int volatile u_int | ia_wake_en:1:1 |
volatile u_int volatile u_int | magic_pkt_dis:1 |
volatile u_int volatile u_int | tx_fc_dis:1 |
volatile u_int volatile u_int | rx_fc_restop:1 |
volatile u_int volatile u_int | rx_fc_restart:1 |
volatile u_int volatile u_int | fc_filter:1 |
volatile u_int volatile u_int | force_fdx:1 |
volatile u_int volatile u_int | fdx_pin_en:1 |
volatile | pri_fc_loc:1 |
volatile | multi_ia:1 |
volatile volatile | u_int:1:3 |
volatile volatile | mc_all:1 |
