uint8_t * | hw_addr |
uint8_t * | flash_address |
em_mac_type | mac_type |
em_phy_type | phy_type |
uint32_t | phy_init_script |
em_media_type | media_type |
void * | back |
em_fc_type | fc |
em_bus_speed | bus_speed |
em_bus_width | bus_width |
em_bus_type | bus_type |
struct em_eeprom_info | eeprom |
em_ms_type | master_slave |
em_ms_type | original_master_slave |
em_ffe_config | ffe_config_state |
uint32_t | asf_firmware_present |
uint32_t | eeprom_semaphore_present |
unsigned long | io_base |
uint32_t | phy_id |
uint32_t | phy_revision |
uint32_t | phy_addr |
uint32_t | original_fc |
uint32_t | txcw |
uint32_t | autoneg_failed |
uint32_t | max_frame_size |
uint32_t | min_frame_size |
uint32_t | mc_filter_type |
uint32_t | num_mc_addrs |
uint32_t | collision_delta |
uint32_t | tx_packet_delta |
uint32_t | ledctl_default |
uint32_t | ledctl_mode1 |
uint32_t | ledctl_mode2 |
boolean_t | tx_pkt_filtering |
struct em_host_mng_dhcp_cookie | mng_cookie |
uint16_t | phy_spd_default |
uint16_t | autoneg_advertised |
uint16_t | pci_cmd_word |
uint16_t | fc_high_water |
uint16_t | fc_low_water |
uint16_t | fc_pause_time |
uint16_t | current_ifs_val |
uint16_t | ifs_min_val |
uint16_t | ifs_max_val |
uint16_t | ifs_step_size |
uint16_t | ifs_ratio |
uint16_t | device_id |
uint16_t | vendor_id |
uint16_t | subsystem_id |
uint16_t | subsystem_vendor_id |
uint8_t | revision_id |
uint8_t | autoneg |
uint8_t | mdix |
uint8_t | forced_speed_duplex |
uint8_t | wait_autoneg_complete |
uint8_t | dma_fairness |
uint8_t | mac_addr [NODE_ADDRESS_SIZE] |
uint8_t | perm_mac_addr [NODE_ADDRESS_SIZE] |
boolean_t | disable_polarity_correction |
boolean_t | speed_downgraded |
em_smart_speed | smart_speed |
em_dsp_config | dsp_config_state |
boolean_t | get_link_status |
boolean_t | serdes_link_down |
boolean_t | tbi_compatibility_en |
boolean_t | tbi_compatibility_on |
boolean_t | phy_reset_disable |
boolean_t | fc_send_xon |
boolean_t | fc_strict_ieee |
boolean_t | report_tx_early |
boolean_t | adaptive_ifs |
boolean_t | ifs_params_forced |
boolean_t | in_ifs_mode |
boolean_t | mng_reg_access_disabled |
