RTEMS
5.1
Convert String to Pointer (with validation) More...
#include <rtems.h>Go to the source code of this file.
| rtems_status_code | rtems_string_to_pointer (const char *s, void **n, char **endptr) |
| Convert String to Pointer (with validation). More... | |
| rtems_status_code | rtems_string_to_unsigned_char (const char *s, unsigned char *n, char **endptr, int base) |
| Convert String to Unsigned Character (with validation). More... | |
| rtems_status_code | rtems_string_to_int (const char *s, int *n, char **endptr, int base) |
| Convert String to Int (with validation). More... | |
| rtems_status_code | rtems_string_to_unsigned_int (const char *s, unsigned int *n, char **endptr, int base) |
| Convert String to Unsigned Int (with validation). More... | |
| rtems_status_code | rtems_string_to_long (const char *s, long *n, char **endptr, int base) |
| Convert String to Long (with validation). More... | |
| rtems_status_code | rtems_string_to_unsigned_long (const char *s, unsigned long *n, char **endptr, int base) |
| Convert String to Unsigned Long (with validation). More... | |
| rtems_status_code | rtems_string_to_long_long (const char *s, long long *n, char **endptr, int base) |
| Convert String to Long Long (with validation). More... | |
| rtems_status_code | rtems_string_to_unsigned_long_long (const char *s, unsigned long long *n, char **endptr, int base) |
| Convert String to Unsigned Long Long (with validation). More... | |
| rtems_status_code | rtems_string_to_float (const char *s, float *n, char **endptr) |
| Convert String to Float (with validation). More... | |
| rtems_status_code | rtems_string_to_double (const char *s, double *n, char **endptr) |
| Convert String to Double (with validation). More... | |
| rtems_status_code | rtems_string_to_long_double (const char *s, long double *n, char **endptr) |
| Convert String to long double (with validation). More... | |
This file defines the interface to a set of string conversion helpers.
1.8.15
