RTEMS
5.1
Constants and Structures Associated with the Object Handler. More...
| union | Objects_Name |
Typedefs | |
| typedef uint32_t | Objects_Id |
| typedef uint16_t | Objects_Maximum |
Enumerations | |
| enum | Objects_APIs { OBJECTS_NO_API = 0, OBJECTS_INTERNAL_API = 1, OBJECTS_CLASSIC_API = 2, OBJECTS_POSIX_API = 3, OBJECTS_FAKE_OBJECTS_API = 7 } |
| RTEMS_INLINE_ROUTINE Objects_APIs | _Objects_Get_API (Objects_Id id) |
| Returns the API portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Objects_Get_class (Objects_Id id) |
| Returns the class portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Objects_Get_node (Objects_Id id) |
| Returns the node portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE Objects_Maximum | _Objects_Get_index (Objects_Id id) |
| Returns the index portion of the ID. More... | |
This include file contains all the constants and structures associated with the Object Handler. This Handler provides mechanisms which can be used to initialize and manipulate all objects which have ids.
1.8.15
