RTEMS
5.1
Inlined Routines Associated with the Manipulation of the Scheduler. More...
#include <rtems/score/scheduler.h>#include <rtems/score/assert.h>#include <rtems/score/priorityimpl.h>#include <rtems/score/smpimpl.h>#include <rtems/score/status.h>#include <rtems/score/threadimpl.h>Go to the source code of this file.
| void | _Scheduler_Handler_initialization (void) |
| Initializes the scheduler to the policy chosen by the user. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_Context * | _Scheduler_Get_context (const Scheduler_Control *scheduler) |
| Gets the context of the scheduler. More... | |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get_by_CPU (const Per_CPU_Control *cpu) |
| Gets the scheduler for the cpu. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Acquire_critical (const Scheduler_Control *scheduler, ISR_lock_Context *lock_context) |
| Acquires the scheduler instance inside a critical section (interrupts disabled). More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Release_critical (const Scheduler_Control *scheduler, ISR_lock_Context *lock_context) |
| Releases the scheduler instance inside a critical section (interrupts disabled). More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Schedule (Thread_Control *the_thread) |
| General scheduling decision. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Yield (Thread_Control *the_thread) |
| Scheduler yield with a particular thread. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Block (Thread_Control *the_thread) |
| Blocks a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Unblock (Thread_Control *the_thread) |
| Unblocks a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Update_priority (Thread_Control *the_thread) |
| Propagates a priority change of a thread to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE Priority_Control | _Scheduler_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Maps a thread priority from the user domain to the scheduler domain. More... | |
| RTEMS_INLINE_ROUTINE Priority_Control | _Scheduler_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Unmaps a thread priority from the scheduler domain to the user domain. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes a scheduler node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Node_destroy (const Scheduler_Control *scheduler, Scheduler_Node *node) |
| Destroys a scheduler node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Release_job (Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
| Releases a job of a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Cancel_job (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Cancels a job of a thread with respect to the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Tick (const Per_CPU_Control *cpu) |
| Scheduler method invoked at each clock tick. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, Per_CPU_Control *cpu) |
| Starts the idle thread for a particular processor. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_Has_processor_ownership (const Scheduler_Control *scheduler, uint32_t cpu_index) |
| Checks if the scheduler of the cpu with the given index is equal to the given scheduler. More... | |
| RTEMS_INLINE_ROUTINE const Processor_mask * | _Scheduler_Get_processors (const Scheduler_Control *scheduler) |
| Gets the processors of the scheduler. More... | |
| bool | _Scheduler_Get_affinity (Thread_Control *the_thread, size_t cpusetsize, cpu_set_t *cpuset) |
| Copies the thread's scheduler's affinity to the given cpuset. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_default_Set_affinity_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, const Processor_mask *affinity) |
| Checks if the affinity is a subset of the online processors. More... | |
| bool | _Scheduler_Set_affinity (Thread_Control *the_thread, size_t cpusetsize, const cpu_set_t *cpuset) |
| Sets the thread's scheduler's affinity. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Generic_block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, void(*extract)(const Scheduler_Control *, Thread_Control *, Scheduler_Node *), void(*schedule)(const Scheduler_Control *, Thread_Control *, bool)) |
| Blocks the thread. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_processor_count (const Scheduler_Control *scheduler) |
| Gets the number of processors of the scheduler. More... | |
| RTEMS_INLINE_ROUTINE Objects_Id | _Scheduler_Build_id (uint32_t scheduler_index) |
| Builds an object build id. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_index_by_id (Objects_Id id) |
| Gets the scheduler index from the given object build id. More... | |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * | _Scheduler_Get_by_id (Objects_Id id) |
| Gets the scheduler from the given object build id. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Scheduler_Get_index (const Scheduler_Control *scheduler) |
| Gets the index of the scheduler. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_Update_heir (Thread_Control *new_heir, bool force_dispatch) |
| Updates the heir. More... | |
| RTEMS_INLINE_ROUTINE Status_Control | _Scheduler_Set (const Scheduler_Control *new_scheduler, Thread_Control *the_thread, Priority_Control priority) |
| Sets a new scheduler. More... | |
This inline file contains all of the inlined routines associated with the manipulation of the scheduler.
1.8.15
