RTEMS
5.1
EDF SMP Scheduler API. More...
#include <rtems/score/scheduler.h>#include <rtems/score/scheduleredf.h>#include <rtems/score/schedulersmp.h>Go to the source code of this file.
| struct | Scheduler_EDF_SMP_Node |
| struct | Scheduler_EDF_SMP_Ready_queue |
| struct | Scheduler_EDF_SMP_Context |
| #define | SCHEDULER_EDF_SMP_ENTRY_POINTS |
| void | _Scheduler_EDF_SMP_Initialize (const Scheduler_Control *scheduler) |
| Initializes the context of the scheduler control. More... | |
| void | _Scheduler_EDF_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given priority. More... | |
| void | _Scheduler_EDF_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Blocks the thread. More... | |
| void | _Scheduler_EDF_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Unblocks the thread. More... | |
| void | _Scheduler_EDF_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the node. More... | |
| bool | _Scheduler_EDF_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help operation. More... | |
| void | _Scheduler_EDF_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help operation. More... | |
| void | _Scheduler_EDF_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws node operation. More... | |
| void | _Scheduler_EDF_SMP_Pin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu) |
| Pin thread operation. More... | |
| void | _Scheduler_EDF_SMP_Unpin (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, struct Per_CPU_Control *cpu) |
| Unpin thread operation. More... | |
| void | _Scheduler_EDF_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds processor. More... | |
| Thread_Control * | _Scheduler_EDF_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. More... | |
| void | _Scheduler_EDF_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| Performs the yield of a thread. More... | |
| void | _Scheduler_EDF_SMP_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu) |
| Starts an idle thread. More... | |
| bool | _Scheduler_EDF_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity) |
| Checks if the processor set of the scheduler is the subset of the affinity set. More... | |
1.8.15
