RTEMS
5.1
Definition of the interface between stub and gdb. More...
| struct | rtems_gdb_stub_thread_info |
| #define | QM_MAX_THREADS (20) |
| Max number of threads in qM response. | |
| #define | MEMOPT_READABLE 1 |
| #define | MEMOPT_WRITEABLE 2 |
| #define | NUM_MEMSEGS 10 |
MIPS registers | |
Numbered in the order in which gdb expects to see them. | |
| #define | ZERO 0 |
| #define | AT 1 |
| #define | V0 2 |
| #define | V1 3 |
| #define | A0 4 |
| #define | A1 5 |
| #define | A2 6 |
| #define | A3 7 |
| #define | T0 8 |
| #define | T1 9 |
| #define | T2 10 |
| #define | T3 11 |
| #define | T4 12 |
| #define | T5 13 |
| #define | T6 14 |
| #define | T7 15 |
| #define | S0 16 |
| #define | S1 17 |
| #define | S2 18 |
| #define | S3 19 |
| #define | S4 20 |
| #define | S5 21 |
| #define | S6 22 |
| #define | S7 23 |
| #define | T8 24 |
| #define | T9 25 |
| #define | K0 26 |
| #define | K1 27 |
| #define | GP 28 |
| #define | SP 29 |
| #define | S8 30 |
| #define | RA 31 |
| #define | SR 32 |
| #define | LO 33 |
| #define | HI 34 |
| #define | BAD_VA 35 |
| #define | CAUSE 36 |
| #define | PC 37 |
| #define | F0 38 |
| #define | F1 39 |
| #define | F2 40 |
| #define | F3 41 |
| #define | F4 42 |
| #define | F5 43 |
| #define | F6 44 |
| #define | F7 45 |
| #define | F8 46 |
| #define | F9 47 |
| #define | F10 48 |
| #define | F11 49 |
| #define | F12 50 |
| #define | F13 51 |
| #define | F14 52 |
| #define | F15 53 |
| #define | F16 54 |
| #define | F17 55 |
| #define | F18 56 |
| #define | F19 57 |
| #define | F20 58 |
| #define | F21 59 |
| #define | F22 60 |
| #define | F23 61 |
| #define | F24 62 |
| #define | F25 63 |
| #define | F26 64 |
| #define | F27 65 |
| #define | F28 66 |
| #define | F29 67 |
| #define | F30 68 |
| #define | F31 69 |
| #define | FCSR 70 |
| #define | FIRR 71 |
| #define | NUM_REGS 72 |
| void | mips_gdb_stub_install (int enableThreads) |
| int | gdbstub_add_memsegment (unsigned, unsigned, int) |
Prototypes | |
| int | parse_zbreak (const char *in, int *type, unsigned char **addr, int *len) |
| char * | mem2hstr (char *buf, const unsigned char *mem, int count) |
| int | hstr2mem (unsigned char *mem, const char *buf, int count) |
| void | set_mem_err (void) |
| unsigned char | get_byte (const unsigned char *ptr) |
| void | set_byte (unsigned char *ptr, int val) |
| char * | thread2vhstr (char *buf, int thread) |
| char * | thread2fhstr (char *buf, int thread) |
| const char * | fhstr2thread (const char *buf, int *thread) |
| const char * | vhstr2thread (const char *buf, int *thread) |
| char * | int2fhstr (char *buf, int val) |
| char * | int2vhstr (char *buf, int vali) |
| const char * | fhstr2int (const char *buf, int *ival) |
| const char * | vhstr2int (const char *buf, int *ival) |
| int | hstr2byte (const char *buf, int *bval) |
| int | hstr2nibble (const char *buf, int *nibble) |
| Thread_Control * | rtems_gdb_index_to_stub_id (int) |
| int | rtems_gdb_stub_thread_support_ok (void) |
| int | rtems_gdb_stub_get_current_thread (void) |
| int | rtems_gdb_stub_get_next_thread (int) |
| int | rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr) |
| int | rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers) |
| int | rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers) |
| void | rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread) |
1.8.15
