RTEMS
5.1
definition of the interface between the stub and gdb More...
| struct | rtems_gdb_stub_thread_info |
| #define | QM_MAX_THREADS (20) |
| #define | MEMOPT_READABLE 1 |
| #define | MEMOPT_WRITEABLE 2 |
| #define | NUM_MEMSEGS 10 |
| int | parse_zbreak (const char *in, int *type, unsigned char **addr, int *len) |
| char * | mem2hstr (char *buf, const unsigned char *mem, int count) |
| int | hstr2mem (unsigned char *mem, const char *buf, int count) |
| void | set_mem_err (void) |
| unsigned char | get_byte (const unsigned char *ptr) |
| void | set_byte (unsigned char *ptr, int val) |
| char * | thread2vhstr (char *buf, int thread) |
| char * | thread2fhstr (char *buf, int thread) |
| const char * | fhstr2thread (const char *buf, int *thread) |
| const char * | vhstr2thread (const char *buf, int *thread) |
| char * | int2fhstr (char *buf, int val) |
| char * | int2vhstr (char *buf, int vali) |
| const char * | fhstr2int (const char *buf, int *ival) |
| const char * | vhstr2int (const char *buf, int *ival) |
| int | hstr2byte (const char *buf, int *bval) |
| int | hstr2nibble (const char *buf, int *nibble) |
| Thread_Control * | rtems_gdb_index_to_stub_id (int) |
| int | rtems_gdb_stub_thread_support_ok (void) |
| int | rtems_gdb_stub_get_current_thread (void) |
| int | rtems_gdb_stub_get_next_thread (int) |
| int | rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr) |
| int | rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers) |
| int | rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers) |
| void | rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread) |
| int | gdbstub_add_memsegment (unsigned, unsigned, int) |
1.8.15
