#define | LEON_INTERRUPT_EXTERNAL_1 5 |
#define | LEON_TRAP_TYPE(_source) SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10) |
#define | LEON_TRAP_SOURCE(_trap) ((_trap) - 0x10) |
| #define | LEON_INT_TRAP(_trap) |
#define | LEON_MEMORY_CONFIGURATION_PROM_SIZE_MASK 0x0003C000 |
#define | LEON_MEMORY_CONFIGURATION_RAM_SIZE_MASK 0x00001E00 |
#define | LEON_REG_TIMER_CONTROL_EN 0x00000001 /* 1 = enable counting */ |
#define | LEON_REG_TIMER_CONTROL_RL 0x00000002 /* 1 = reload at 0 */ |
#define | LEON_REG_TIMER_CONTROL_LD 0x00000004 /* 1 = load counter */ |
#define | LEON_REG_UART_CONTROL_RTD 0x000000FF /* RX/TX data */ |
#define | LEON_REG_UART_STATUS_DR 0x00000001 /* Data Ready */ |
#define | LEON_REG_UART_STATUS_TSE 0x00000002 /* TX Send Register Empty */ |
#define | LEON_REG_UART_STATUS_THE 0x00000004 /* TX Hold Register Empty */ |
#define | LEON_REG_UART_STATUS_BR 0x00000008 /* Break Error */ |
#define | LEON_REG_UART_STATUS_OE 0x00000010 /* RX Overrun Error */ |
#define | LEON_REG_UART_STATUS_PE 0x00000020 /* RX Parity Error */ |
#define | LEON_REG_UART_STATUS_FE 0x00000040 /* RX Framing Error */ |
#define | LEON_REG_UART_STATUS_TF 0x00000200 /* FIFO Full */ |
#define | LEON_REG_UART_STATUS_ERR 0x00000078 /* Error Mask */ |
#define | LEON_REG_UART_CTRL_RE 0x00000001 /* Receiver enable */ |
#define | LEON_REG_UART_CTRL_TE 0x00000002 /* Transmitter enable */ |
#define | LEON_REG_UART_CTRL_RI 0x00000004 /* Receiver interrupt enable */ |
#define | LEON_REG_UART_CTRL_TI 0x00000008 /* Transmitter interrupt enable */ |
#define | LEON_REG_UART_CTRL_PS 0x00000010 /* Parity select */ |
#define | LEON_REG_UART_CTRL_PE 0x00000020 /* Parity enable */ |
#define | LEON_REG_UART_CTRL_FL 0x00000040 /* Flow control enable */ |
#define | LEON_REG_UART_CTRL_LB 0x00000080 /* Loop Back enable */ |
#define | LEON_REG_UART_CTRL_DB 0x00000800 /* Debug FIFO enable */ |
#define | LEON_REG_UART_CTRL_SI 0x00004000 /* TX shift register empty IRQ enable */ |
#define | LEON_REG_UART_CTRL_FA 0x80000000 /* FIFO Available */ |
#define | LEON_REG_UART_CTRL_FA_BIT 31 |
#define | LEON3_REG_CACHE_CTRL_FI 0x00200000 /* Flush instruction cache */ |
#define | LEON3_REG_CACHE_CTRL_DS 0x00800000 /* Data cache snooping */ |
#define | LEON3_IRQMPSTATUS_CPUNR 28 |
#define | LEON3_IRQMPSTATUS_BROADCAST 27 |
#define | LEON3_IRQCTRL_ACQUIRE(_lock_context) rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context ) |
#define | LEON3_IRQCTRL_RELEASE(_lock_context) rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context ) |
| #define | LEON_Clear_interrupt(_source) |
| #define | LEON_Force_interrupt(_source) |
| #define | LEON_Enable_interrupt_broadcast(_source) |
| #define | LEON_Disable_interrupt_broadcast(_source) |
#define | LEON_Is_interrupt_pending(_source) (LEON3_IrqCtrl_Regs->ipend & (1U << (_source))) |
#define | LEON_Cpu_Is_interrupt_masked(_source, _cpu) (!(LEON3_IrqCtrl_Regs->mask[_cpu] & (1U << (_source)))) |
| #define | LEON_Cpu_Mask_interrupt(_source, _cpu) |
| #define | LEON_Cpu_Unmask_interrupt(_source, _cpu) |
| #define | LEON_Cpu_Disable_interrupt(_source, _previous, _cpu) |
| #define | LEON_Cpu_Restore_interrupt(_source, _previous, _cpu) |
#define | LEON_Is_interrupt_masked(_source) LEON_Cpu_Is_interrupt_masked(_source, _LEON3_Get_current_processor()) |
#define | LEON_Mask_interrupt(_source) LEON_Cpu_Mask_interrupt(_source, _LEON3_Get_current_processor()) |
#define | LEON_Unmask_interrupt(_source) LEON_Cpu_Unmask_interrupt(_source, _LEON3_Get_current_processor()) |
#define | LEON_Disable_interrupt(_source, _previous) LEON_Cpu_Disable_interrupt(_source, _previous, _LEON3_Get_current_processor()) |
#define | LEON_Restore_interrupt(_source, _previous) LEON_Cpu_Restore_interrupt(_source, _previous, _LEON3_Get_current_processor()) |
#define | BSP_Clear_interrupt(_source) LEON_Clear_interrupt(_source) |
#define | BSP_Force_interrupt(_source) LEON_Force_interrupt(_source) |
#define | BSP_Is_interrupt_pending(_source) LEON_Is_interrupt_pending(_source) |
#define | BSP_Is_interrupt_masked(_source) LEON_Is_interrupt_masked(_source) |
#define | BSP_Unmask_interrupt(_source) LEON_Unmask_interrupt(_source) |
#define | BSP_Mask_interrupt(_source) LEON_Mask_interrupt(_source) |
#define | BSP_Disable_interrupt(_source, _previous) LEON_Disable_interrupt(_source, _prev) |
#define | BSP_Restore_interrupt(_source, _previous) LEON_Restore_interrupt(_source, _previous) |
#define | BSP_Cpu_Is_interrupt_masked(_source, _cpu) LEON_Cpu_Is_interrupt_masked(_source, _cpu) |
#define | BSP_Cpu_Unmask_interrupt(_source, _cpu) LEON_Cpu_Unmask_interrupt(_source, _cpu) |
#define | BSP_Cpu_Mask_interrupt(_source, _cpu) LEON_Cpu_Mask_interrupt(_source, _cpu) |
#define | BSP_Cpu_Disable_interrupt(_source, _previous, _cpu) LEON_Cpu_Disable_interrupt(_source, _prev, _cpu) |
#define | BSP_Cpu_Restore_interrupt(_source, _previous, _cpu) LEON_Cpu_Restore_interrupt(_source, _previous, _cpu) |
#define | LEON_REG_TIMER_COUNTER_RELOAD_AT_ZERO 0x00000002 |
#define | LEON_REG_TIMER_COUNTER_STOP_AT_ZERO 0x00000000 |
#define | LEON_REG_TIMER_COUNTER_LOAD_COUNTER 0x00000004 |
#define | LEON_REG_TIMER_COUNTER_ENABLE_COUNTING 0x00000001 |
#define | LEON_REG_TIMER_COUNTER_DISABLE_COUNTING 0x00000000 |
#define | LEON_REG_TIMER_COUNTER_RELOAD_MASK 0x00000002 |
#define | LEON_REG_TIMER_COUNTER_ENABLE_MASK 0x00000001 |
#define | LEON_REG_TIMER_COUNTER_DEFINED_MASK 0x00000003 |
#define | LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK 0x00000003 |
#define | LEON3_CLOCK_INDEX 0 |
#define | LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX |
#define | LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000 |
LEON3 BSP data types and macros.
