RTEMS
5.1
ISR Level Type. More...
| #define | _ISR_Local_disable(_level) |
| Disables interrupts on this processor. More... | |
| #define | _ISR_Local_enable(_level) |
| Enables interrupts on this processor. More... | |
| #define | _ISR_Local_flash(_level) |
| Temporarily enables interrupts on this processor. More... | |
| #define | _ISR_Is_enabled(_level) _CPU_ISR_Is_enabled( _level ) |
| Returns true if interrupts are enabled in the specified interrupt level, otherwise returns false. More... | |
| #define | _ISR_Get_level() _CPU_ISR_Get_level() |
| Return current interrupt level. More... | |
| #define | _ISR_Set_level(_new_level) |
| Set current interrupt level. More... | |
Typedefs | |
| typedef uint32_t | ISR_Level |
ISR Level Type.
This include file defines the ISR Level type. It exists to simplify include dependencies. It is part of the ISR Handler.
1.8.15
