RTEMS
5.1
Generic BSP interrupt support implementation. More...
#include <bsp/irq-generic.h>#include <bsp/fatal.h>#include <stdlib.h>#include <rtems/score/processormask.h>#include <rtems/malloc.h>Functions | |
| void | bsp_interrupt_initialize (void) |
| Initialize BSP interrupt support. More... | |
| rtems_status_code | rtems_interrupt_handler_install (rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg) |
| Installs the interrupt handler routine handler for the interrupt vector with number vector. More... | |
| rtems_status_code | rtems_interrupt_handler_remove (rtems_vector_number vector, rtems_interrupt_handler handler, void *arg) |
| Removes the interrupt handler routine handler with argument arg for the interrupt vector with number vector. More... | |
| rtems_status_code | rtems_interrupt_handler_iterate (rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg) |
| Iterates over all installed interrupt handler of the interrupt vector with number vector. More... | |
| bool | bsp_interrupt_handler_is_empty (rtems_vector_number vector) |
| Is interrupt handler empty. More... | |
| rtems_status_code | rtems_interrupt_set_affinity (rtems_vector_number vector, size_t affinity_size, const cpu_set_t *affinity) |
| Sets the processor affinity set of an interrupt vector. More... | |
| rtems_status_code | rtems_interrupt_get_affinity (rtems_vector_number vector, size_t affinity_size, cpu_set_t *affinity) |
| Gets the processor affinity set of an interrupt vector. More... | |
| bsp_interrupt_handler_entry | bsp_interrupt_handler_table [BSP_INTERRUPT_HANDLER_TABLE_SIZE] |
1.8.15
