| bool | _Heap_Get_first_and_last_block (uintptr_t heap_area_begin, uintptr_t heap_area_size, uintptr_t page_size, uintptr_t min_block_size, Heap_Block **first_block_ptr, Heap_Block **last_block_ptr) |
| | Gets the first and last block for the heap area. More...
| uintptr_t | _Heap_Initialize (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size) |
| | Initializes the heap control block. More...
| void * | _Heap_Allocate_aligned_with_boundary (Heap_Control *heap, uintptr_t size, uintptr_t alignment, uintptr_t boundary) |
| | Allocates an aligned memory area with boundary constraint. More...
| RTEMS_INLINE_ROUTINE void * | _Heap_Allocate_aligned (Heap_Control *heap, uintptr_t size, uintptr_t alignment) |
| | Allocates an aligned memory area. More...
| RTEMS_INLINE_ROUTINE void * | _Heap_Allocate (Heap_Control *heap, uintptr_t size) |
| | Allocates a memory area. More...
| bool | _Heap_Free (Heap_Control *heap, void *addr) |
| | Frees the allocated memory area. More...
| bool | _Heap_Walk (Heap_Control *heap, int source, bool dump) |
| | Verifies the integrity of the heap. More...
| void | _Heap_Iterate (Heap_Control *heap, Heap_Block_visitor visitor, void *visitor_arg) |
| | Iterates over all blocks of the heap. More...
| Heap_Block * | _Heap_Greedy_allocate (Heap_Control *heap, const uintptr_t *block_sizes, size_t block_count) |
| | Greedily allocates and empties the heap. More...
| Heap_Block * | _Heap_Greedy_allocate_all_except_largest (Heap_Control *heap, uintptr_t *allocatable_size) |
| | Greedily allocates all blocks except the largest free block. More...
| void | _Heap_Greedy_free (Heap_Control *heap, Heap_Block *blocks) |
| | Frees blocks of a greedy allocation. More...
| void | _Heap_Get_information (Heap_Control *heap, Heap_Information_block *info) |
| | Returns information about used and free blocks for the heap. More...
| void | _Heap_Get_free_information (Heap_Control *heap, Heap_Information *info) |
| | Returns information about free blocks for the heap. More...
| bool | _Heap_Size_of_alloc_area (Heap_Control *heap, void *addr, uintptr_t *size) |
| | Returns the size of the allocatable memory area. More...
| Heap_Resize_status | _Heap_Resize_block (Heap_Control *heap, void *addr, uintptr_t size, uintptr_t *old_size, uintptr_t *new_size) |
| | Resizes the block of the allocated memory area. More...
| Heap_Block * | _Heap_Block_allocate (Heap_Control *heap, Heap_Block *block, uintptr_t alloc_begin, uintptr_t alloc_size) |
| | Allocates the memory area. starting at alloc_begin of size alloc_size bytes in the block block. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Protection_set_delayed_free_fraction (Heap_Control *heap, uintptr_t fraction) |
| | Sets the fraction of delayed free blocks that is actually freed during memory shortage. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Free_list_head (Heap_Control *heap) |
| | Returns the head of the free list of the heap. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Free_list_tail (Heap_Control *heap) |
| | Returns the tail of the free list of the heap. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Free_list_first (Heap_Control *heap) |
| | Returns the first block of the free list of the heap. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Free_list_last (Heap_Control *heap) |
| | Returns the last block of the free list of the heap. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Free_list_remove (Heap_Block *block) |
| | Removes the block from the free list. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Free_list_replace (Heap_Block *old_block, Heap_Block *new_block) |
| | Replaces one block in the free list by another. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Free_list_insert_after (Heap_Block *block_before, Heap_Block *new_block) |
| | Inserts a block after an existing block in the free list. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Free_list_insert_before (Heap_Block *block_next, Heap_Block *new_block) |
| | Inserts a block before an existing block in the free list. More...
| RTEMS_INLINE_ROUTINE bool | _Heap_Is_aligned (uintptr_t value, uintptr_t alignment) |
| | Checks if the value is aligned to the given alignment. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Align_down (uintptr_t value, uintptr_t alignment) |
| | Returns the aligned value, truncating. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Block_at (const Heap_Block *block, uintptr_t offset) |
| | Returns the block which is offset away from block. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Prev_block (const Heap_Block *block) |
| | Returns the address of the previous block. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Alloc_area_of_block (const Heap_Block *block) |
| | Returns the first address in the block without the heap header. More...
| RTEMS_INLINE_ROUTINE Heap_Block * | _Heap_Block_of_alloc_area (uintptr_t alloc_begin, uintptr_t page_size) |
| | Returns the starting address of the block corresponding to the allocatable area. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Block_size (const Heap_Block *block) |
| | Returns the block size. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Block_set_size (Heap_Block *block, uintptr_t size) |
| | Sets the block size. More...
| RTEMS_INLINE_ROUTINE bool | _Heap_Is_prev_used (const Heap_Block *block) |
| | Returns if the previous heap block is used. More...
| RTEMS_INLINE_ROUTINE bool | _Heap_Is_used (const Heap_Block *block) |
| | Returns if the heap block is used. More...
| RTEMS_INLINE_ROUTINE bool | _Heap_Is_free (const Heap_Block *block) |
| | Returns if the heap block is free. More...
| RTEMS_INLINE_ROUTINE bool | _Heap_Is_block_in_heap (const Heap_Control *heap, const Heap_Block *block) |
| | Returns if the block is part of the heap. More...
| RTEMS_INLINE_ROUTINE void | _Heap_Set_last_block_size (Heap_Control *heap) |
| | Sets the size of the last block for the heap. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Get_size (const Heap_Control *heap) |
| | Returns the size of the allocatable area in bytes. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Max (uintptr_t a, uintptr_t b) |
| | Returns the bigger one of the two arguments. More...
| RTEMS_INLINE_ROUTINE uintptr_t | _Heap_Min (uintptr_t a, uintptr_t b) |
| | Returns the smaller one of the two arguments. More...
Heap Handler Implementation.
