| rtems_status_code | rtems_chain_append_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events) |
| | Appends the node to the chain and sends the events to the task if the chain was empty before the append. More...
| rtems_status_code | rtems_chain_prepend_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events) |
| | Prepends the node to the chain and sends the events to the task if the chain was empty before the prepend. More...
| rtems_status_code | rtems_chain_get_with_notification (rtems_chain_control *chain, rtems_id task, rtems_event_set events, rtems_chain_node **node) |
| | Gets the first node of the chain and sends the events to the task if the chain is empty after the get. More...
| rtems_status_code | rtems_chain_get_with_wait (rtems_chain_control *chain, rtems_event_set events, rtems_interval timeout, rtems_chain_node **node) |
| | Gets the first node of the chain and sends the events to the task if the chain is empty afterwards. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_initialize (rtems_chain_control *the_chain, void *starting_address, size_t number_nodes, size_t node_size) |
| | Initialize a chain Header. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_initialize_empty (rtems_chain_control *the_chain) |
| | Initialize this chain as empty. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_set_off_chain (rtems_chain_node *node) |
| | Set off chain. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_initialize_node (rtems_chain_node *node) |
| | Initializes a chain node. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_node_off_chain (const rtems_chain_node *node) |
| | Is the node off chain. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_null_node (const rtems_chain_node *the_node) |
| | Is the chain node pointer NULL. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_head (rtems_chain_control *the_chain) |
| | Return pointer to Chain Head. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_head (const rtems_chain_control *the_chain) |
| | Return pointer to immutable Chain Head. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_tail (rtems_chain_control *the_chain) |
| | Return pointer to Chain Tail. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_tail (const rtems_chain_control *the_chain) |
| | Return pointer to immutable Chain Tail. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_first (const rtems_chain_control *the_chain) |
| | Return pointer to Chain's First node after the permanent head. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_first (const rtems_chain_control *the_chain) |
| | Return pointer to immutable Chain's First node. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_last (const rtems_chain_control *the_chain) |
| | Return pointer to Chain's Last node before the permanent tail. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_last (const rtems_chain_control *the_chain) |
| | Return pointer to immutable Chain's Last node. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_next (const rtems_chain_node *the_node) |
| | Return pointer the next node from this node. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_next (const rtems_chain_node *the_node) |
| | Return pointer the immutable next node from this node. More...
| RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_previous (const rtems_chain_node *the_node) |
| | Return pointer the previous node from this node. More...
| RTEMS_INLINE_ROUTINE const rtems_chain_node * | rtems_chain_immutable_previous (const rtems_chain_node *the_node) |
| | Return pointer the immutable previous node from this node. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_are_nodes_equal (const rtems_chain_node *left, const rtems_chain_node *right) |
| | Are Two nodes equal. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_empty (const rtems_chain_control *the_chain) |
| | Is the chain empty. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_first (const rtems_chain_node *the_node) |
| | Is this the first node on the chain. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_last (const rtems_chain_node *the_node) |
| | Is this the last node on the chain. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_has_only_one_node (const rtems_chain_control *the_chain) |
| | Does this chain have only one node. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_head (const rtems_chain_control *the_chain, const rtems_chain_node *the_node) |
| | Is this node the chain head. More...
| RTEMS_INLINE_ROUTINE bool | rtems_chain_is_tail (const rtems_chain_control *the_chain, const rtems_chain_node *the_node) |
| | Is this node the chain tail. More...
| void | rtems_chain_extract (rtems_chain_node *the_node) |
| | Extract the specified node from a chain. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_extract_unprotected (rtems_chain_node *the_node) |
| | Extract the specified node from a chain (unprotected). More...
| rtems_chain_node * | rtems_chain_get (rtems_chain_control *the_chain) |
| | Obtain the first node on a chain. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_get_unprotected (rtems_chain_control *the_chain) |
| | See _Chain_Get_unprotected().
RTEMS_INLINE_ROUTINE rtems_chain_node * | rtems_chain_get_first_unprotected (rtems_chain_control *the_chain) |
| | See _Chain_Get_first_unprotected().
| void | rtems_chain_insert (rtems_chain_node *after_node, rtems_chain_node *the_node) |
| | Insert a node on a chain. More...
RTEMS_INLINE_ROUTINE void | rtems_chain_insert_unprotected (rtems_chain_node *after_node, rtems_chain_node *the_node) |
| | See _Chain_Insert_unprotected().
| void | rtems_chain_append (rtems_chain_control *the_chain, rtems_chain_node *the_node) |
| | Append a node on the end of a chain. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_append_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node) |
| | Append a node on the end of a chain (unprotected). More...
| void | rtems_chain_prepend (rtems_chain_control *the_chain, rtems_chain_node *the_node) |
| | Prepend a node. More...
| RTEMS_INLINE_ROUTINE void | rtems_chain_prepend_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node) |
| | Prepend a node (unprotected). More...
| bool | rtems_chain_append_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node) |
| | Checks if the chain is empty and appends the node. More...
| bool | rtems_chain_prepend_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node) |
| | Checks if the chain is empty and prepends the node. More...
| bool | rtems_chain_get_with_empty_check (rtems_chain_control *chain, rtems_chain_node **node) |
| | Tries to get the first node and check if the chain is empty afterwards. More...
| RTEMS_INLINE_ROUTINE size_t | rtems_chain_node_count_unprotected (const rtems_chain_control *chain) |
| | Returns the node count of the chain. More...
