Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <leon.h>
#include <rtems/irq-extension.h>
#define | LEON3 1 |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | BSP_NUMBER_OF_TERMIOS_PORTS 8 |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME_OPENETH "open_eth1" |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH rtems_leon_open_eth_driver_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME_SMC91111 "smc_eth1" |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 rtems_smc91111_driver_attach_leon3 |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH "gr_eth1" |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH rtems_leon_greth_driver_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME RTEMS_BSP_NETWORK_DRIVER_NAME_GRETH |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH RTEMS_BSP_NETWORK_DRIVER_ATTACH_GRETH |
#define | HAS_SMC91111 |
#define | GRETH_SUPPORTED |
#define | GRETH_MEM_LOAD(addr) leon_r32_no_cache((uintptr_t)addr) |
#define | AMBAPPBUS_INFO_AVAIL /* AMBAPP Bus driver */ |
#define | APBUART_INFO_AVAIL /* APBUART Console driver */ |
#define | GPTIMER_INFO_AVAIL /* GPTIMER Timer driver */ |
#define | GRETH_INFO_AVAIL /* GRETH Ethernet driver */ |
typedef void(* | bsp_shared_isr) (void *arg) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| | Optimized idle task. More...
int | rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach) |
int | rtems_smc91111_driver_attach_leon3 (struct rtems_bsdnet_ifconfig *config, int attach) |
int | rtems_leon_greth_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| | Install an interrupt handler. More...
void | BSP_fatal_exit (uint32_t error) |
void | bsp_spurious_initialize (void) |
void | rtems_bsp_delay (int usecs) |
void | BSP_shared_interrupt_init (void) |
void | bsp_isr_handler (rtems_vector_number vector) |
void | BSP_shared_interrupt_clear (int irq) |
void | BSP_shared_interrupt_unmask (int irq) |
void | BSP_shared_interrupt_mask (int irq) |
int | CPU_SPARC_HAS_SNOOPING |
int | RAM_START |
int | RAM_END |
int | RAM_SIZE |
int | PROM_START |
int | PROM_END |
int | PROM_SIZE |
int | CLOCK_SPEED |
int | end |
