| enum | ALT_16550_DEVICE_e { ALT_16550_DEVICE_SOCFPGA_UART0 = 0,
ALT_16550_DEVICE_SOCFPGA_UART1 = 1,
ALT_16550_DEVICE_ALTERA_16550_UART = 0x100
| enum | ALT_16550_FIFO_TRIGGER_RX_e { ALT_16550_FIFO_TRIGGER_RX_ANY = 0,
ALT_16550_FIFO_TRIGGER_RX_QUARTER_FULL = 1,
ALT_16550_FIFO_TRIGGER_RX_HALF_FULL = 2,
ALT_16550_FIFO_TRIGGER_RX_ALMOST_FULL = 3
| enum | ALT_16550_FIFO_TRIGGER_TX_e { ALT_16550_FIFO_TRIGGER_TX_EMPTY = 0,
ALT_16550_FIFO_TRIGGER_TX_ALMOST_EMPTY = 1,
ALT_16550_FIFO_TRIGGER_TX_QUARTER_FULL = 2,
ALT_16550_FIFO_TRIGGER_TX_HALF_FULL = 3
| enum | ALT_16550_BAUDRATE_e {
ALT_16550_BAUDRATE_50 = 50,
ALT_16550_BAUDRATE_75 = 75,
ALT_16550_BAUDRATE_150 = 150,
ALT_16550_BAUDRATE_300 = 300,
ALT_16550_BAUDRATE_600 = 600,
ALT_16550_BAUDRATE_900 = 900,
ALT_16550_BAUDRATE_1200 = 1200,
ALT_16550_BAUDRATE_1800 = 1800,
ALT_16550_BAUDRATE_2400 = 2400,
ALT_16550_BAUDRATE_3600 = 3600,
ALT_16550_BAUDRATE_4800 = 4800,
ALT_16550_BAUDRATE_7200 = 7200,
ALT_16550_BAUDRATE_9600 = 9600,
ALT_16550_BAUDRATE_14400 = 14400,
ALT_16550_BAUDRATE_19200 = 19200,
ALT_16550_BAUDRATE_28800 = 28800,
ALT_16550_BAUDRATE_38400 = 38400,
ALT_16550_BAUDRATE_57600 = 57600,
ALT_16550_BAUDRATE_115200 = 115200
| enum | ALT_16550_INT_STATUS_e {
ALT_16550_INT_STATUS_LINE = 0x6,
ALT_16550_INT_STATUS_RX_DATA = 0x4,
ALT_16550_INT_STATUS_RX_TIMEOUT = 0xC,
ALT_16550_INT_STATUS_TX_IDLE = 0x2,
ALT_16550_INT_STATUS_MODEM = 0x0,
ALT_16550_INT_STATUS_NONE = 0x1
| enum | ALT_16550_MODEM_STATUS_e {
ALT_16550_MODEM_STATUS_DCD = 1 << 7,
ALT_16550_MODEM_STATUS_RI = 1 << 6,
ALT_16550_MODEM_STATUS_DSR = 1 << 5,
ALT_16550_MODEM_STATUS_CTS = 1 << 4,
ALT_16550_MODEM_STATUS_DDCD = 1 << 3,
ALT_16550_MODEM_STATUS_TERI = 1 << 2,
ALT_16550_MODEM_STATUS_DDSR = 1 << 1,
ALT_16550_MODEM_STATUS_DCTS = 1 << 0
| enum | ALT_16550_DATABITS_e { ALT_16550_DATABITS_5 = 0,
ALT_16550_DATABITS_6 = 1,
ALT_16550_DATABITS_7 = 2,
ALT_16550_DATABITS_8 = 3
| enum | ALT_16550_STOPBITS_e { ALT_16550_STOPBITS_1 = 0,
ALT_16550_STOPBITS_2 = 1
| enum | ALT_16550_PARITY_e { ALT_16550_PARITY_DISABLE = 0,
ALT_16550_PARITY_ODD = 1,
ALT_16550_PARITY_EVEN = 2
| enum | ALT_16550_LINE_STATUS_e {
ALT_16550_LINE_STATUS_RFE = 1 << 7,
ALT_16550_LINE_STATUS_TEMT = 1 << 6,
ALT_16550_LINE_STATUS_THRE = 1 << 5,
ALT_16550_LINE_STATUS_BI = 1 << 4,
ALT_16550_LINE_STATUS_FE = 1 << 3,
ALT_16550_LINE_STATUS_PE = 1 << 2,
ALT_16550_LINE_STATUS_OE = 1 << 1,
ALT_16550_LINE_STATUS_DR = 1 << 0
| ALT_STATUS_CODE | alt_16550_init (ALT_16550_DEVICE_t device, void *location, alt_freq_t clock_freq, ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_uninit (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_reset (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_read (ALT_16550_HANDLE_t *handle, char *item) |
| ALT_STATUS_CODE | alt_16550_write (ALT_16550_HANDLE_t *handle, char item) |
| ALT_STATUS_CODE | alt_16550_fifo_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_fifo_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_fifo_read (ALT_16550_HANDLE_t *handle, char *buffer, size_t count) |
| ALT_STATUS_CODE | alt_16550_fifo_write (ALT_16550_HANDLE_t *handle, const char *buffer, size_t count) |
| ALT_STATUS_CODE | alt_16550_fifo_clear_rx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_fifo_clear_tx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_fifo_clear_all (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_fifo_size_get_rx (ALT_16550_HANDLE_t *handle, uint32_t *size) |
| ALT_STATUS_CODE | alt_16550_fifo_size_get_tx (ALT_16550_HANDLE_t *handle, uint32_t *size) |
| ALT_STATUS_CODE | alt_16550_fifo_level_get_rx (ALT_16550_HANDLE_t *handle, uint32_t *level) |
| ALT_STATUS_CODE | alt_16550_fifo_level_get_tx (ALT_16550_HANDLE_t *handle, uint32_t *level) |
| ALT_STATUS_CODE | alt_16550_fifo_trigger_set_rx (ALT_16550_HANDLE_t *handle, ALT_16550_FIFO_TRIGGER_RX_t trigger) |
| ALT_STATUS_CODE | alt_16550_fifo_trigger_set_tx (ALT_16550_HANDLE_t *handle, ALT_16550_FIFO_TRIGGER_TX_t trigger) |
| ALT_STATUS_CODE | alt_16550_baudrate_get (ALT_16550_HANDLE_t *handle, uint32_t *baudrate) |
| ALT_STATUS_CODE | alt_16550_baudrate_set (ALT_16550_HANDLE_t *handle, uint32_t baudrate) |
| ALT_STATUS_CODE | alt_16550_divisor_get (ALT_16550_HANDLE_t *handle, uint32_t *divisor) |
| ALT_STATUS_CODE | alt_16550_divisor_set (ALT_16550_HANDLE_t *handle, uint32_t divisor) |
| ALT_STATUS_CODE | alt_16550_int_enable_rx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_disable_rx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_enable_tx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_disable_tx (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_enable_line (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_disable_line (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_enable_modem (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_disable_modem (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_disable_all (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_int_status_get (ALT_16550_HANDLE_t *handle, ALT_16550_INT_STATUS_t *status) |
| ALT_STATUS_CODE | alt_16550_flowcontrol_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_flowcontrol_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_loopback_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_loopback_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_enable_out1 (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_disable_out1 (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_enable_out2 (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_disable_out2 (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_enable_rts (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_disable_rts (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_enable_dtr (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_disable_dtr (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_modem_status_get (ALT_16550_HANDLE_t *handle, uint32_t *status) |
| ALT_STATUS_CODE | alt_16550_line_config_set (ALT_16550_HANDLE_t *handle, ALT_16550_DATABITS_t databits, ALT_16550_PARITY_t parity, ALT_16550_STOPBITS_t stopbits) |
| ALT_STATUS_CODE | alt_16550_line_break_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_line_break_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_line_status_get (ALT_16550_HANDLE_t *handle, uint32_t *status) |
