RTEMS
5.1
Information Required to Manipulate Physical Addresses. More...
#include <rtems/score/cpu.h>Go to the source code of this file.
| RTEMS_INLINE_ROUTINE void * | _Addresses_Add_offset (const void *base, uintptr_t offset) |
| Adds offset to an address. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Subtract_offset (const void *base, uintptr_t offset) |
| Subtracts offset from an address. More... | |
| RTEMS_INLINE_ROUTINE intptr_t | _Addresses_Subtract (const void *left, const void *right) |
| Subtracts two addresses. More... | |
| RTEMS_INLINE_ROUTINE bool | _Addresses_Is_aligned (const void *address) |
| Checks if address is aligned. More... | |
| RTEMS_INLINE_ROUTINE bool | _Addresses_Is_in_range (const void *address, const void *base, const void *limit) |
| Checks if address is in range. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Align_up (void *address, size_t alignment) |
| Aligns address to nearest multiple of alignment, rounding up. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Align_down (void *address, size_t alignment) |
| Aligns address to nearest multiple of alignment, truncating. More... | |
This include file contains the information required to manipulate physical addresses.
1.8.15
