score
cpu
avr
avr
wdt.h
1
6
/* Copyright (c) 2002, 2004 Marek Michalkiewicz
7
Copyright (c) 2005, 2006, 2007 Eric B. Weddington
8
All rights reserved.
9
10
Redistribution and use in source and binary forms, with or without
11
modification, are permitted provided that the following conditions are met:
12
13
* Redistributions of source code must retain the above copyright
14
notice, this list of conditions and the following disclaimer.
15
16
* Redistributions in binary form must reproduce the above copyright
17
notice, this list of conditions and the following disclaimer in
18
the documentation and/or other materials provided with the
19
distribution.
20
21
* Neither the name of the copyright holders nor the names of
22
contributors may be used to endorse or promote products derived
23
from this software without specific prior written permission.
24
25
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
POSSIBILITY OF SUCH DAMAGE. */
36
37
38
39
avr/wdt.h - macros for AVR watchdog timer
40
41
42
#ifndef _AVR_WDT_H_
43
#define _AVR_WDT_H_
44
45
avr/io.h
46
#include <stdint.h>
47
104
#define wdt_reset() __asm__ __volatile__ ("wdr")
105
106
107
#if defined(WDP3)
108
# define _WD_PS3_MASK _BV(WDP3)
109
#else
110
# define _WD_PS3_MASK 0x00
111
#endif
112
113
#if defined(WDTCSR)
114
# define _WD_CONTROL_REG WDTCSR
115
#else
116
# define _WD_CONTROL_REG WDTCR
117
#endif
118
119
#if defined(WDTOE)
120
#define _WD_CHANGE_BIT WDTOE
121
#else
122
#define _WD_CHANGE_BIT WDCE
123
#endif
124
125
137
#if defined(__AVR_ATxmega16A4__) \
138
|| defined(__AVR_ATxmega16D4__) \
139
|| defined(__AVR_ATxmega32A4__) \
140
|| defined(__AVR_ATxmega32D4__) \
141
|| defined(__AVR_ATxmega64A1__) \
142
|| defined(__AVR_ATxmega64A3__) \
143
|| defined(__AVR_ATxmega64D3__) \
144
|| defined(__AVR_ATxmega128A1__) \
145
|| defined(__AVR_ATxmega128A3__) \
146
|| defined(__AVR_ATxmega128D3__) \
147
|| defined(__AVR_ATxmega192A3__) \
148
|| defined(__AVR_ATxmega192D3__) \
149
|| defined(__AVR_ATxmega256A3__) \
150
|| defined(__AVR_ATxmega256D3__) \
151
|| defined(__AVR_ATxmega256A3B__)
152
153
154
wdt_enable(WDT_PER_8KCLK_gc);
155
156
#define wdt_enable(value) \
157
__asm__ __volatile__ ( \
158
"in __tmp_reg__, %0" "\n\t" \
159
"out %1, %3" "\n\t" \
160
"sts %2, %4" "\n\t" \
161
"wdr" "\n\t" \
162
"out %0, __tmp_reg__" "\n\t" \
163
164
: "M" (_SFR_MEM_ADDR(RAMPD)), \
165
"M" (_SFR_MEM_ADDR(CCP)), \
166
"M" (_SFR_MEM_ADDR(WDT_CTRL)), \
167
"r" ((uint8_t)0xD8), \
168
"r" ((uint8_t)(WDT_CEN_bm | WDT_ENABLE_bm | value)) \
169
: "r0" \
170
171
172
173
#elif defined(__AVR_AT90CAN32__) \
174
|| defined(__AVR_AT90CAN64__) \
175
|| defined(__AVR_AT90CAN128__) \
176
|| defined(__AVR_AT90PWM1__) \
177
|| defined(__AVR_AT90PWM2__) \
178
|| defined(__AVR_AT90PWM216__) \
179
|| defined(__AVR_AT90PWM2B__) \
180
|| defined(__AVR_AT90PWM3__) \
181
|| defined(__AVR_AT90PWM316__) \
182
|| defined(__AVR_AT90PWM3B__) \
183
|| defined(__AVR_AT90PWM81__) \
184
|| defined(__AVR_AT90USB1286__) \
185
|| defined(__AVR_AT90USB1287__) \
186
|| defined(__AVR_AT90USB162__) \
187
|| defined(__AVR_AT90USB646__) \
188
|| defined(__AVR_AT90USB647__) \
189
|| defined(__AVR_AT90USB82__) \
190
|| defined(__AVR_ATmega1280__) \
191
|| defined(__AVR_ATmega1281__) \
192
|| defined(__AVR_ATmega1284P__) \
193
|| defined(__AVR_ATmega128RFA1__) \
194
|| defined(__AVR_ATmega164__) \
195
|| defined(__AVR_ATmega164A__) \
196
|| defined(__AVR_ATmega164P__) \
197
|| defined(__AVR_ATmega165__) \
198
|| defined(__AVR_ATmega165A__) \
199
|| defined(__AVR_ATmega165P__) \
200
|| defined(__AVR_ATmega168__) \
201
|| defined(__AVR_ATmega168A__) \
202
|| defined(__AVR_ATmega168P__) \
203
|| defined(__AVR_ATmega169__) \
204
|| defined(__AVR_ATmega169A__) \
205
|| defined(__AVR_ATmega169P__) \
206
|| defined(__AVR_ATmega169PA__) \
207
|| defined(__AVR_ATmega16HVA__) \
208
|| defined(__AVR_ATmega16HVA2__) \
209
|| defined(__AVR_ATmega16HVB__) \
210
|| defined(__AVR_ATmega16M1__) \
211
|| defined(__AVR_ATmega16U2__) \
212
|| defined(__AVR_ATmega16U4__) \
213
|| defined(__AVR_ATmega2560__) \
214
|| defined(__AVR_ATmega2561__) \
215
|| defined(__AVR_ATmega324__) \
216
|| defined(__AVR_ATmega324A__) \
217
|| defined(__AVR_ATmega324P__) \
218
|| defined(__AVR_ATmega324PA__) \
219
|| defined(__AVR_ATmega325__) \
220
|| defined(__AVR_ATmega3250__) \
221
|| defined(__AVR_ATmega328__) \
222
|| defined(__AVR_ATmega328P__) \
223
|| defined(__AVR_ATmega329__) \
224
|| defined(__AVR_ATmega329P__) \
225
|| defined(__AVR_ATmega329PA__) \
226
|| defined(__AVR_ATmega3290__) \
227
|| defined(__AVR_ATmega3290P__) \
228
|| defined(__AVR_ATmega32C1__) \
229
|| defined(__AVR_ATmega32HVB__) \
230
|| defined(__AVR_ATmega32M1__) \
231
|| defined(__AVR_ATmega32U2__) \
232
|| defined(__AVR_ATmega32U4__) \
233
|| defined(__AVR_ATmega32U6__) \
234
|| defined(__AVR_ATmega406__) \
235
|| defined(__AVR_ATmega48__) \
236
|| defined(__AVR_ATmega48A__) \
237
|| defined(__AVR_ATmega48P__) \
238
|| defined(__AVR_ATmega640__) \
239
|| defined(__AVR_ATmega644__) \
240
|| defined(__AVR_ATmega644A__) \
241
|| defined(__AVR_ATmega644P__) \
242
|| defined(__AVR_ATmega644PA__) \
243
|| defined(__AVR_ATmega645__) \
244
|| defined(__AVR_ATmega645A__) \
245
|| defined(__AVR_ATmega645P__) \
246
|| defined(__AVR_ATmega6450__) \
247
|| defined(__AVR_ATmega6450A__) \
248
|| defined(__AVR_ATmega6450P__) \
249
|| defined(__AVR_ATmega649__) \
250
|| defined(__AVR_ATmega649A__) \
251
|| defined(__AVR_ATmega6490__) \
252
|| defined(__AVR_ATmega6490A__) \
253
|| defined(__AVR_ATmega6490P__) \
254
|| defined(__AVR_ATmega649P__) \
255
|| defined(__AVR_ATmega64C1__) \
256
|| defined(__AVR_ATmega64HVE__) \
257
|| defined(__AVR_ATmega64M1__) \
258
|| defined(__AVR_ATmega88__) \
259
|| defined(__AVR_ATmega88A__) \
260
|| defined(__AVR_ATmega88P__) \
261
|| defined(__AVR_ATmega88PA__) \
262
|| defined(__AVR_ATmega8HVA__) \
263
|| defined(__AVR_ATmega8U2__) \
264
|| defined(__AVR_ATtiny48__) \
265
|| defined(__AVR_ATtiny88__) \
266
|| defined(__AVR_ATtiny87__) \
267
|| defined(__AVR_ATtiny167__) \
268
|| defined(__AVR_AT90SCR100__) \
269
|| defined(__AVR_ATA6289__)
270
271
/* Use STS instruction. */
272
273
274
275
"in __tmp_reg__,__SREG__" "\n\t" \
276
"cli" "\n\t" \
277
"wdr" "\n\t" \
278
"sts %0,%1" "\n\t" \
279
"out __SREG__,__tmp_reg__" "\n\t" \
280
"sts %0,%2" "\n\t" \
281
/* no outputs */
282
: "M" (_SFR_MEM_ADDR(_WD_CONTROL_REG)), \
283
"r" (_BV(_WD_CHANGE_BIT) | _BV(WDE)), \
284
"r" ((uint8_t) ((value & 0x08 ? _WD_PS3_MASK : 0x00) | \
285
_BV(WDE) | (value & 0x07)) ) \
286
: "r0" \
287
288
289
#define wdt_disable() \
290
291
"in __tmp_reg__, __SREG__" "\n\t" \
292
"cli" "\n\t" \
293
"sts %0, %1" "\n\t" \
294
"sts %0, __zero_reg__" "\n\t" \
295
296
/* no outputs */
297
298
"r" ((uint8_t)(_BV(_WD_CHANGE_BIT) | _BV(WDE))) \
299
: "r0" \
300
301
302
303
304
#else
305
306
/* Use OUT instruction. */
307
308
309
310
311
"cli" "\n\t" \
312
"wdr" "\n\t" \
313
"out %0,%1" "\n\t" \
314
315
"out %0,%2" \
316
/* no outputs */
317
: "I" (_SFR_IO_ADDR(_WD_CONTROL_REG)), \
318
319
320
321
: "r0" \
322
323
329
330
331
332
"cli" "\n\t" \
333
"out %0, %1" "\n\t" \
334
"out %0, __zero_reg__" "\n\t" \
335
336
/* no outputs */
337
338
339
: "r0" \
340
341
342
#endif
343
344
345
367
#define WDTO_15MS 0
368
370
#define WDTO_30MS 1
371
373
#define WDTO_60MS 2
374
376
#define WDTO_120MS 3
377
379
#define WDTO_250MS 4
380
382
#define WDTO_500MS 5
383
385
#define WDTO_1S 6
386
388
#define WDTO_2S 7
389
390
#if defined(__DOXYGEN__) || defined(WDP3)
391
412
#define WDTO_4S 8
413
415
#define WDTO_8S 9
416
417
#endif
/* defined(__DOXYGEN__) || defined(WDP3) */
418
420
#endif
/* _AVR_WDT_H_ */
io.h
AVR device-specific IO Definitions.
