libmisc
uuid
uuidd.h
1
2
* Definitions used by the uuidd daemon
3
4
* Copyright (C) 2007 Theodore Ts'o.
5
6
* %Begin-Header%
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, and the entire permission notice in its entirety,
12
* including the disclaimer of warranties.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
* 3. The name of the author may not be used to endorse or promote
17
* products derived from this software without specific prior
18
* written permission.
19
20
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
21
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
22
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ALL OF
23
* WHICH ARE HEREBY DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE
24
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
26
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
27
* BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
28
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
29
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
30
* USE OF THIS SOFTWARE, EVEN IF NOT ADVISED OF THE POSSIBILITY OF SUCH
31
* DAMAGE.
32
* %End-Header%
33
34
35
#ifndef _UUID_UUIDD_H
36
#define _UUID_UUIDD_H
37
38
#define UUIDD_SOCKET_PATH "/var/lib/libuuid/request"
39
#define UUIDD_PIDFILE_PATH "/var/lib/libuuid/uuidd.pid"
40
#define UUIDD_PATH "/usr/sbin/uuidd"
41
42
#define UUIDD_OP_GETPID 0
43
#define UUIDD_OP_GET_MAXOP 1
44
#define UUIDD_OP_TIME_UUID 2
45
#define UUIDD_OP_RANDOM_UUID 3
46
#define UUIDD_OP_BULK_TIME_UUID 4
47
#define UUIDD_OP_BULK_RANDOM_UUID 5
48
#define UUIDD_MAX_OP UUIDD_OP_BULK_RANDOM_UUID
49
50
extern
void
uuid__generate_time(uuid_t out,
int
*num);
51
extern
void
uuid__generate_random(uuid_t out,
int
*num);
52
53
#endif
/* _UUID_UUID_H */
