libmisc
shell
sysexits.h
1
2
* Copyright (c) 1987, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 3. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)sysexits.h 8.1 (Berkeley) 6/2/93
30
31
* $FreeBSD: release/9.1.0/include/sysexits.h 203964 2010-02-16 19:39:50Z imp $
32
33
34
#ifndef _SYSEXITS_H_
35
#define _SYSEXITS_H_
36
37
38
* SYSEXITS.H -- Exit status codes for system programs.
39
40
* This include file attempts to categorize possible error
41
* exit statuses for system programs, notably delivermail
42
* and the Berkeley network.
43
44
* Error numbers begin at EX__BASE to reduce the possibility of
45
* clashing with other exit statuses that random programs may
46
* already return. The meaning of the codes is approximately
47
* as follows:
48
49
* EX_USAGE -- The command was used incorrectly, e.g., with
50
* the wrong number of arguments, a bad flag, a bad
51
* syntax in a parameter, or whatever.
52
* EX_DATAERR -- The input data was incorrect in some way.
53
* This should only be used for user's data & not
54
* system files.
55
* EX_NOINPUT -- An input file (not a system file) did not
56
* exist or was not readable. This could also include
57
* errors like "No message" to a mailer (if it cared
58
* to catch it).
59
* EX_NOUSER -- The user specified did not exist. This might
60
* be used for mail addresses or remote logins.
61
* EX_NOHOST -- The host specified did not exist. This is used
62
* in mail addresses or network requests.
63
* EX_UNAVAILABLE -- A service is unavailable. This can occur
64
* if a support program or file does not exist. This
65
* can also be used as a catchall message when something
66
* you wanted to do doesn't work, but you don't know
67
* why.
68
* EX_SOFTWARE -- An internal software error has been detected.
69
* This should be limited to non-operating system related
70
* errors as possible.
71
* EX_OSERR -- An operating system error has been detected.
72
* This is intended to be used for such things as "cannot
73
* fork", "cannot create pipe", or the like. It includes
74
* things like getuid returning a user that does not
75
* exist in the passwd file.
76
* EX_OSFILE -- Some system file (e.g., /etc/passwd, /etc/utmp,
77
* etc.) does not exist, cannot be opened, or has some
78
* sort of error (e.g., syntax error).
79
* EX_CANTCREAT -- A (user specified) output file cannot be
80
* created.
81
* EX_IOERR -- An error occurred while doing I/O on some file.
82
* EX_TEMPFAIL -- temporary failure, indicating something that
83
* is not really an error. In sendmail, this means
84
* that a mailer (e.g.) could not create a connection,
85
* and the request should be reattempted later.
86
* EX_PROTOCOL -- the remote system returned something that
87
* was "not possible" during a protocol exchange.
88
* EX_NOPERM -- You did not have sufficient permission to
89
* perform the operation. This is not intended for
90
* file system problems, which should use NOINPUT or
91
* CANTCREAT, but rather for higher level permissions.
92
93
94
#define EX_OK 0
/* successful termination */
95
96
#define EX__BASE 64
/* base value for error messages */
97
98
#define EX_USAGE 64
/* command line usage error */
99
#define EX_DATAERR 65
/* data format error */
100
#define EX_NOINPUT 66
/* cannot open input */
101
#define EX_NOUSER 67
/* addressee unknown */
102
#define EX_NOHOST 68
/* host name unknown */
103
#define EX_UNAVAILABLE 69
/* service unavailable */
104
#define EX_SOFTWARE 70
/* internal software error */
105
#define EX_OSERR 71
/* system error (e.g., can't fork) */
106
#define EX_OSFILE 72
/* critical OS file missing */
107
#define EX_CANTCREAT 73
/* can't create (user) output file */
108
#define EX_IOERR 74
/* input/output error */
109
#define EX_TEMPFAIL 75
/* temp failure; user is invited to retry */
110
#define EX_PROTOCOL 76
/* remote error in protocol */
111
#define EX_NOPERM 77
/* permission denied */
112
#define EX_CONFIG 78
/* configuration error */
113
114
#define EX__MAX 78
/* maximum listed value */
115
116
#endif
/* !_SYSEXITS_H_ */
